question about heater not getting hot
Old 10-17-2008, 06:02 PM
Countryhick's Avatar
My ac doesnt work or my Heater.
Its either my blown head.
Heater core
Or i dont havea thermostat in my truck
lol im guessing on one and 3.
and also my engine is very loud when i rev it up.
is there away to make this very quite?
Old 10-17-2008, 06:22 PM
abecedarian's Avatar
well, if the heater won't blow warm air (considering the dash fan runs) then either the heater core is plugged or the valve that regulates coolant through the heater core is plugged or stuck or the coolant lines back to the water pump are clogged, or the control rod that connects the temp lever to that valve is stuck.
that has little if any influence on the a/c though, if the lever is moved all the way over to cold, so no heat does not mean the problem/cause/solution is the same as no a/c.
but let's go back to the engine... what do you mean the engine is very loud?
Old 10-17-2008, 06:34 PM
the fan and everything. its just loud. like air loud.
Old 10-17-2008, 06:40 PM
not understanding....
you turn the heater/ac fan on and it's loud?
Old 10-17-2008, 07:04 PM
stoicheg2's Avatar
A previous car i had worked on had this same problem. Turned out to be air in the system... alot of it.
what does the coolant temperature gauge read when the engine is "warmed up"?
Old 10-17-2008, 07:43 PM
right in the middle after awhile.
and just all around the engine is loud. just all around is loud. revs out really loud not like normally my 22re did or my buddys 3.0 v6 does. got any ideas on how to make it quite?
the1998sr5
15
07-14-2020 08:35 PM
94 Newbie
08-06-2015 10:33 AM
Bucksnuff
07-31-2015 07:09 AM
jjrbus
07-19-2015 02:06 PM
the1998sr5
07-16-2015 06:20 AM
Quick Reply: question about heater not getting hot
