Québec law on lifted trucks
New law in Québec for SUV's and pick-ups :
Max tire size over stock 3"
Max mechanical lift 2.5"
Max pneumatic lift ( as in contact patch to centerline of wheel ) 1.5"
Max overall lift combined : 4.0"
Good thing I bought the 33's as I was tempted to do some 35's !
So I'll be doing a 1.5" ball joint spacer with relaxed torsions
Lower my body lift to 2" from the 3" that came on truck ( glad for that )
Run my 33's on a 15 x 8 alloy with near stock backspace and
Jungle Flares to tuck the wheel a bit.
This will be legal enough to avoid issues with the police.
I'll be carrying a printed copy of the SAAQ document to
show and tell the cops.
Sad news for Quebecers, you heard it first on Yotatech !
Inches? In Québec? Sacre bleu!
Is this the document to which you refer? http://www.saaq.gouv.qc.ca/documents...f_artisan.html (apparently updated sometime in 2013)
Oui, hahaha !
Yes the guys just got wind of it on the Quebec forum.
Cops are doing their spring safety crackdown and rigs
are getting taken off the road in droves.
http://www.quebec4x4.com/forum/showthread.php?t=158730
Based on these rules, all toyota 4runners/ tacomas are illegal in quebec:
27. A neutral start
An automatic transmission vehicle must be fitted with a neutral start which cuts the starter current on all speed selections, except for the neutral (N) or P (Park).
A manual transmission vehicle must be equipped with a device for engine start only when the clutch pedal is pressed or when the gear lever is in neutral.
27. A neutral start
6th Gear
19
12-10-2019 07:31 AM
duckhead
07-17-2015 04:45 AM
88Toy
7
06-17-2015 09:40 AM
