Puzzling Brake Issues...
Hello, all!
I just put a new inner seal on my 94 runner's left rear axle, and had to crack the brake line to get the axle off. I had taken the axle off several days before to replace the O-ring, and after getting it all back together, bleeding the brakes and final assembly, everything was fine in the braking department.
Fast forward to yesterday, I remove the axle, replace the old inner seal, and put everything back together exactly the same way as before, including bleeding the brakes, but now I have a spongy pedal.
What gives?
Today, I bled the system starting from right rear, going to left rear, right front and then left front, THEN bleeding at both connections on the master cylinder. I got a few bubbles from both front calipers, but none from anywhere else in the system.
I can't help but think that there is still an errant air bubble somewhere in the system, but I'm at a loss to find it after bleeding the system three times. The brake pedal is spongy, but after pumping it up, it holds brake pressure with no let-off. I checked the booster per the instructions in the service manual, and it checks out. No hissing or loss of brake pressure.
I'm stumped!
Anyone else encounter anything like this?
What gives?
I'm stumped!
Try this:
1. Push the pedal so that it holds a fairly high pressure.
2. Somehow secure the brake pedal in place (rod/2x4/whatever btwn the pedal and the seat brackets for example)
3. Tap on the calipers and wheel cylinders with a plastic, rubber, or rawhide hammer.
4. Walk away.
5. Tomorrow, tap stuff again
6. Remove the rod and gently release the brake pedal.
7. Check how they feel
More times than not with autos and 100% on motorcycles, this has worked for me to fix 'rogue' air and a soft initial pedal due to it. The high pressure compresses the air bubbles and allows them to move.
Free and easy!
Good luck.
_____________
4. Walk away.
Free and easy!
Good luck.
_____________
You could also have a connection sucking air back into the system. This could be caused by a tiny piece of grit or dirt not allowing the flare fitting to seal 100%
The brake fluid leak is so small it would be very hard to notice
I chased a problem like this for a few weeks a real pain
Ok, I've tried bleeding the brakes and the fittings on the master cylinder, and I still have a spongy pedal, so now I'm wondering if the ABS system has anything to do with this.
There isn't any mention of the ABS system in the bleeding instructions, but I can't help but think that it would be affected by opening up part of the brake hydraulic system.
I don't see any bleeder fittings on the ABS assembly, and haven't located any instructions about bleeding it.
Anyone got any ideas, or know of any information sources that might help me figure this out?
Got it! Bled the LSPV, which was NOT on the frame rail as I thought, but directly above and behind the chunk housing. After that, I adjusted the parking brake and the truck started behaving itself again.
Now, time to look for a new windshield and some new springs and shocks to get rid of the saggy ass on my Runner!
Thanks for the input, y'all!
1uzRunner
63
11-10-2018 03:58 PM
