putting my window in, glue?
im to thepoing where my new diverside window is ready to go in on my 94 4runner, now, the part that bolts to the regulator, how should i secure that to the glass? i want it to work smoothly and outlast the truck.
an good solid solutions?
I went to autozone and got some of that glue they use to glue a windshield back onto a vehicle. It's a black almost like silicone stuff. Anyway, I pressed the metal slides on the bottom and had to use a rubber mallet to get them on all the way. Right before I did that I coated all surfaces with a thin layer of that stuff. So far it has done the trick for me.
I don't care if it shows up because it's on the channel guides which are on the bottom of the window and never show. Outside of tearing apart your door have you ever seen a channel guide?
Seriously, if I had known what the stuff was I would have used silicone because it's cheaper but that's because I'm a redneck and like to save a dollar. So in that sense, I agree with you, 89macrunner.
Whatever you use will probably be okay. Just make sure it's something that will stick to both glass and metal and will have some elastic properties and not just crack everytime there's a little movement and you actually need a material that can be removed (think of your next broken window replacement).
Show us some pictures when you're done. I was doing a thread on here and then my wife deleted all the pictures I took the day I put it back together...
ill post some pics of puttiong it back together.
if it doesnt come apart, i dont mind, thats actualy better in my mind
ill probably try the windshield stuff.
i still want to find those ☺☺☺☺ers and shoot them in the head
jasonty
41
12-23-2018 01:00 PM
FS[PacNorWest]: 1987 Toyota 4Runner $1800 Whidbey Island, WA
coreyedwards7611
01-16-2016 06:38 PM
icentropy
07-14-2015 10:23 AM
FS[SouthEast]: 1st Gen 4Runner Slider Window, Driver Side
coryc85
07-06-2015 04:07 AM
