Put in a new 22R, have some leftover ground wires...
If anyone can take a quick look and tell me where these are supposed to go I would greatly appreciate it
Truck is a carbed 86 4x4
This is right between the two heater hoses
Near the header
Near the header
The top one usually connected to the head and the bottom on the block. But, just connect them...really...to wherever they'll reach on the engine to whatever bolt....just not the valve cover. It's seperated from the head/engine by the rubber gasket....no ground. Those grounds are just to absorb stray currents you may have. They are important, though.
top one connects to the block/head. I have mine connected on the hook on the right side where u would normally take the motor out with a cherry picker.
the bottom one connects to one of the bolts where the power steering pump bracket connects to the block
the1998sr5
15
07-14-2020 08:35 PM
