put engine bak together after sitting for a year
Old 04-26-2012, 07:31 AM
benjie's Avatar
ok i am new to this posting stuff so please bare with me, i have 2 problems it seems one the truck just cranks it wont start i checked all the injectors its getting gas, i also jumpered the diagnostic and it said that the igniter wasntiming t gettn signal to my ecu i replaced it and still nothing could my timing be off i pulled the distributor cap off and it was pointing to number 4 coil not number 1, do i need to reset the timing by setting crank shaft to zero and reinstalling ditributor? now second problem the ground wire coming out of harness to alternator that is connectd to the pulley bracket on engine is burning up when i try to start the truck, when i disconnect the wire the starter only clicks but doesnt turn over what do i need to do fix these problems? all answers and help will be appreciated thank
ok yota techs i have not had time to work on this truck until today. i seem to be getting somewhere the truck is back firing now when i try to start it i get about 2 or 3 back fires any insight thanks
Old 04-26-2012, 08:11 AM
TNRabbit's Avatar
There a little punctuation thing called a PERIOD. Use it & your posts will be much easier to understand.
I think the distributor rotor should be pointing to 11 o'clock when at TDC (?)...
If the ground wire is that hot, sounds like an unfused short somewhere.
If you replaced the ignitor, it sounds like the problem might be in the wiring harness....?
Which engine are we talking about here??
Old 04-26-2012, 09:15 AM
benjie's Avatar
1991 22re 4 cylinder
Old 04-26-2012, 03:40 PM
rokblok's Avatar
Period, Sir!!!
Old 05-01-2012, 03:43 AM
benjie's Avatar
ok yota techs i have not had time to work on this truck until today. i seem to be getting somewhere the truck is back firing now when i try to start it i get about 2 or 3 back fires any insight thanks.
Old 05-01-2012, 05:04 AM
TNRabbit's Avatar
I guess plug wires on the wrong plugs or distributor off a tooth or more.
Hard to guess given it's been apart for a year & we don't know if you put it back together correctly~
Old 05-01-2012, 05:33 AM
Kiroshu's Avatar
#1 Cylinder at TDC(Top dead center) Distributor rotor should be pointing at #1 cyldiner on the Distributor cap and both valves should be closed.
Firing order is 1-3-4-2
Spark coming directly from coil? If not then thats your trouble area.
Fuses?
puffin04
07-10-2015 09:17 PM
saphirekosmos
06-22-2015 10:26 AM
94 First Responder
06-06-2002 02:19 PM
Quick Reply: put engine bak together after sitting for a year
