pulling tranny in 95 runner
Old 08-23-2009, 03:32 PM
biscuit0229's Avatar
I'm pulling the tranny and I'm in a bind on the passenger side by the starter... any clues... no bolts in the way.....
help
Old 08-23-2009, 03:50 PM
yota_mota's Avatar
First of all make absolutely 100% sure there are no bolts holding it, the ones on top are usually hard to see. If you've got everything disconnected, you should just be able to give er a few jerks and then good to go!
Old 08-23-2009, 06:06 PM
Tragic Drive's Avatar
Did you pull the slave cylinder off ?
Did you get both starter bolts off one is in the front and one in the back ?
Old 08-23-2009, 07:27 PM
Tubbyfatty's Avatar
Are all the wires off? Theres one right by the shifters on the passenger side and i almost missed it before i pulled mine.
Also, make sure you arent hitting the shifter plate with the t case shifter inside the cab, i did on mine and i bent it up a bit so i wouldnt fight it anymore.
Old 08-23-2009, 07:42 PM
Staff
DeathCougar's Avatar
Lets start with some more info.
Auto? or Manual trans.
I just did an auto in a 95 4Runner, i could tell you how many and what size the bolts are!
stagger_lee
03-29-2016 06:27 PM
njomba
07-09-2015 04:21 PM
bowhunter1640
07-01-2015 10:31 AM
quaale94TRD
3.4 Swaps
06-23-2015 10:27 AM
crazypaint
06-23-2015 03:27 AM
Quick Reply: pulling tranny in 95 runner
