Pulling bedsides
Pulling bedsides
Has anyone tried this on a 84-88 pickup or 84-89 4runner? I came across this thread on race dezert and i've been considering it. I know it won't look as good as any of the other generation's body style bed's, but I'm thinking that with a little bondo it could look pretty good.
Pros
-more room for larger tires without lift
-with wider wheel wells you can trim your bump stops to allow for more compression travel. Giving your rear axle more articulation with your stock leaf springs. More flex at stock ride height, which is nice for those off camber moments. Or even just more travel for high speed desert running.
-almost free
Cons
-??? fill in the blank ???
Not sure if I can do it on the 4runner, but maybe a good option for you pickup guys
Pros
-almost free
Cons
Hey Pat, you've seen Deathrunner's rig right? That's the way I plan on getting better wheel coverage and clearance when the time is right (i.e. sheet metal cancer finally pisses me off).
just buy my glass http://www.toyotafiberglass.com and modify the wheel well ..
or hech .. if theres enough interested parties .. I will convert myself , and make moulds ...
Keith, how's life in Pennsylvania?
that's about the lowest-tech approach to a wide-body I've ever seen...
personally, I don't like the way it looks in the end; apparently there's a few on here that agree with me...
go fiber man... or maybe just fender flares...
Just maybe not so much of a bulge
I like the stock fiberglass bedsides they make, but then your own steel tailgate is not usable? I am at odds why someone has not stamped out a steel version. Yup the wider desert version looks odd.
