Pullin a vacume
Old 06-16-2007, 06:32 PM
Robrt32's Avatar
Pullin a vacume
I searched pulling a vacume and it came up with nothing anyhow , The AC in my truck is almost fair.. Its cooling but not enough , compressor is fine , no noise kicks right in and runs quiet.. I charged it 2 years ago and it worked fair nothing special but i didin't pull a vacume.. I did not have a pump but ive found somebody to loan me 1 in the morning.. I have 3 cans of fresh freon and a can of oil.. Can anyone tell me the do's and don'ts on pulling the vacume??
Old 06-16-2007, 06:44 PM
Bigblock's Avatar
You dont pull a vaccuum if there is freon in the a/c.
Old 06-16-2007, 06:47 PM
Robrt32's Avatar
Let me try this again, I charged it 2 years ago without pulling a vacume , it never cooled like it was suppose to NOW i want to start over , and pull a vacume.. I want to pretend there no freon in it
Old 06-16-2007, 06:59 PM
1994runner's Avatar
According to the EPA, the correct way to do it if there was freon in the system would be to take it to someone with a freon reclaimer to keep it out of the atmosphere. Definately if it is the old r-12 freon. r-134a is supposed to be better but still not good for the environment.
Now if the system were to develop a mysterious leak...
After the freon is empty hook the guages up to the system an yellow hose to the vacuum pump. If it is an electric pump I generally let it run for 1/2 to an hour.
Air vacuum pumps consume a lot of air so when I used one, I pulled 30 inches of vavuum, closed the valves on the guages and let it sit for an hour under vacuum then add the freon to the low side as usual.
Old 06-16-2007, 07:04 PM
Robrt32's Avatar
Nevermind , I found what i needed through google.. and just for the record I do not buy into Gores global warming SCAM
Old 06-16-2007, 07:43 PM
dijlop's Avatar
on that topic, i find it kinda funny how so many different places recorded record lows last winter. lol.
Old 06-16-2007, 07:47 PM
Drama Queen/Banned
paxil4x4's Avatar
Spoken like a true idiot.
☺☺☺☺ on the planet first
Fix it later
But as long as you have cold A/C it will be worth the legacy
Old 06-16-2007, 07:49 PM
dijlop's Avatar
no worries. i drive with my windows down instead of a/c.
and i only breath 47 times a day. keep down carbon dioxide emitance.
Old 06-16-2007, 08:22 PM
ChickenLover's Avatar
I can't imagine why...
Old 06-16-2007, 08:37 PM
displacedAlaskan's Avatar
I drive with my windows down also, I like the feel of fresh air in my cab. In Alaska, you get use to not using A/C even if your vehicle is equipped with it. I'm down in Florida right now for the time being, and it's pretty hot but I still roll with my windows down. Also I think my a/c needs to be recharged
Old 06-16-2007, 10:06 PM
FredTJ's Avatar
Couple of points:
- It's not Gores global warming
- It's not a scam.
- You're pretty damn foolish.
- What in the heck do you intend on doing with the can of oil ?
The oil's only used if the system is flushed, so you have an end point with which to start.
Without flushing the system, how in the hell do you think you're going to figure how much oil the system needs ?
Fred
Old 06-16-2007, 10:20 PM
nieuwendyk-25's Avatar
I laughed so hard at this and the other posts, I think a little pee came out!
Gotta go "vacume" the rug! Later!
We really need a spell check on this forum! and he really needs some professional !
Originally Posted by FredTJ
Couple of points:
- It's not a scam.
Fred
Good points, but you forgot to mention one Fred
-it's VACUUM
Old 06-17-2007, 10:11 AM
Robrt32's Avatar
Couple of points:
- It's not a scam.
Fred
It works fine..........I'm cool and i'm happy, and if you choose to follow the scam more power to ya.. its free country , you do what you like and i will do the same
Old 06-17-2007, 10:36 AM
frodin1's Avatar
While your at it you should cut all the epa required equipment off your truck since you don't buy into it. Since it all a scam you must not need it there anyway.
Old 06-17-2007, 11:20 AM
HuskyRunner's Avatar
My 4runner is the third vehicle I've owned with a/c, and the third it hasn't frickin' work in! Okay, a/c rant over.
Old 06-17-2007, 12:04 PM
80W90's Avatar
dont release that freon into the atmoshphere.
that is really bad for the atmosphere.
i agree with you on F global warming and all that B/S. put id like to smash you freakin skull into a pulp for releasing the freon into the atmoshpere.
you say its a free country. true. but releasing the spent freon is agaisnt the law.
its not just my coutnry its our country.
china is doing thier part to pollute the ☺☺☺☺☺ out the planet. lets not do the same.
does any one have his IP?
we can forward it to the EPA, they would love to put him in the klink for ten years.
Old 06-17-2007, 03:27 PM
Robrt32's Avatar
Nevermind, not worth it the efford
Old 06-18-2007, 12:47 PM
80W90's Avatar
your right. F uck the enviroment.
Old 06-18-2007, 01:02 PM
Roboito's Avatar
Technically your car gets worse gas mileage with the windows down so the pollution into the atmosphere would be worse... i guess
but i bet the Alaskan air is unreal
PBRaddict#1
08-22-2015 11:34 PM
ThomasJ
09-19-2010 06:41 PM
hellonweels89
09-10-2006 08:24 PM
neil_P_smith
01-31-2005 09:05 PM
Quick Reply: Pullin a vacume
