Which pulley is it?
Old 11-09-2010, 05:18 PM
mapple83's Avatar
Which pulley is it?
there is no diagram for the pulleys in my chilton's repair manual so this is a challenge to you yota vets. my truck- 94 4x4 pu w/ 22re. there are three belts between the radiator and the engine. the pulley is on the belt closest to the radiator, and is the highest on the passenger side. it seems not to have any function except to keep the belt on track and spin, but i don't think it's the tensioner because it doesn't look like it can be adjusted. come on guys i have faith in you! thanks
Old 11-09-2010, 05:33 PM
thralldad's Avatar
pix? not sure what you are asking.
Old 11-09-2010, 05:34 PM
xxxtreme22r's Avatar
maybe take a photo of yours and edit it pointing at which one you mean so someone else doesn't have to? the highest pulley on the passenger side would be the ac compressor f you have AC and the PS tensioner pulley if you don't have AC. I don't know how the AC belt is adjusted but I can tell you that the power steering belt is adjusted by a bolt on the top of the mount which goes to a rod that moves the pully up and down (more left and right though) tightening and loosening the belt.
Old 11-09-2010, 05:52 PM
iamsuperbleeder's Avatar
passenger side?
the belt closest to the radiator is the PS belt, and it's pulleys are all on the driver's side
it's adjusted by the pulley in the center/top, right in front of the cyl head. loosen the center bolt on the pulley, and then tighten the bolt head that points down and to the right at an angle, on the left of the bracket that the pulley is mounted to (not shown in that picture)
Old 11-09-2010, 05:56 PM
hmmm hehe thought for some stupid reason the ac belt was on the outside, but I don't have AC so how would I know, but the passenger side comment threw me off I guess.
Old 11-09-2010, 06:04 PM
mapple83's Avatar
sorry don't have a camera right now. but i do have ac.
Old 11-09-2010, 06:13 PM
mapple83's Avatar
Originally Posted by iamsuperbleeder
passenger side?
sorry for the confusion. by passenger side i meant relative to the pulley on the same belt at the same height. the pulley i was trying to describe is actually the one you referred to as the center/top, right in front of the cyl head. thanks for the pic. so now that we know the pulley, what the hell is it called cuz mine seized up and i need to order a new one. or just the bearing if possible.
Old 11-09-2010, 06:19 PM
BigBluePile's Avatar
Power steering idler pulley...
You can get JUST the bearing thru an auto parts store...or $150 at the dealership...
it's the idler or tensioner pulley. I believe it's this one: http://www.autozone.com/autozone/par...099_4204_7651_
Old 11-09-2010, 06:28 PM
the advantage of get the the dealer one is I believe it comes with a new adjuster bolt as well. But that's a heck of a price difference.
Old 11-09-2010, 06:39 PM
geez, I would hope one form the dealer wouldn't come with chipped edges like that
you would have thought they would have chosen a better pulley for the photo shoot...
Old 11-09-2010, 06:40 PM
Old 11-09-2010, 06:58 PM
mapple83's Avatar
yeah that's the one, but why does it look so different from the original. do i have to reuse the exterior parts (i mean spacers and such) from the original one?
Old 11-09-2010, 06:59 PM
yes see the later posts on what the dealer will give you and you can see how that comes apart.
Old 11-09-2010, 08:52 PM
mapple83's Avatar
so the one from autozone http://www.autozone.com/autozone/par...099_4204_7651_ isn't it. it's too small in diameter.
Old 11-09-2010, 08:58 PM
mapple83's Avatar
is the power steering pump pulley the same as the tensioner then? cuz it's still way more than the idler at oreilly. http://www.oreillyauto.com/site/c/se...ley#vehicleTop
Old 11-10-2010, 04:47 AM
powersteering pump pulley is not the same. that would be on the pump.
what do you mean too small in diameter?
Old 11-10-2010, 05:28 AM
diablo's Avatar
On the idler pulley you can just replace the sealed bearing, instead of buying a new one. The original is better than the aftermarket anyway. The bearing has a snap ring on it and pops out.
Old 11-10-2010, 05:32 AM
toyota doesn't sell just the bearing, you have to get the bearing aftermarket anyway.
Old 11-10-2010, 09:23 AM
mapple83's Avatar
the one i got from autozone is smaller in diameter so when i put it on, i couldn't tighten the tensioning bolt enough to take out the slack in the belt.
Quick Reply: Which pulley is it?
