PU Hood Scoops / Aftermarket Hoods
Old 06-09-2009, 05:21 PM
SwampThing's Avatar
Sooooo. With the ST2 getting a heart transplant, and me refusing to do the 3" body lift, we're having a whole lot of fun trying to fit everything up under the hood. Gonna have to chop the tranny tunnel (clear the 350 -> toy tranny adapter's bellhousing), move the rad back to the tube bed somewhere (get some room up front), and hack the back of the firewall about 2" (clear the distributor).
Pretty much got everything figured out except for the fact that there's gonna hardly any room for the carb, let alone an air cleaner. So I've been toying (hah, pun not intended) with the idea of slapping a hood scoop or getting an aftermarket hood with a 3-4" bulge so I can clear that air cleaner and give the motor a little room for heat dissipation and whatnot.
So, does anyone have any experience with hoodscoops or aftermarket hoods for 84-89 pickups?
Old 06-09-2009, 09:11 PM
space-junk's Avatar
might look cool if you could find a hoodscoop off of a subaru WRX... itll be tall enough and if postioned right should allow you to run a smaller air cleaner assembly without having to do MAJOR surgery to your hood...
plus it would just look damn cool...
Old 06-10-2009, 04:05 PM
Skinsfan6's Avatar
Why the refusal to do a body lift? It will help with keeping wind coming by the block more. And illeviate all the hood clearance problems and most of the firewall problems I would imagine.
But if you refuse to do a body lift I think a cowl induction hood would help with your clearance a lot and also give the hot air an easy route to escape. I probably wouldn't do a front facing scoop if I went in any mud or water. I've been wanting to put a small cowl hood on mine just for cooling purposes. My electric fan pulls cool air through the radiator but then it doesn't really have anywhere to go.
Old 06-10-2009, 04:20 PM
toylocost's Avatar
Location: Yotatech, because Pirate is too expensive. NorCal.
cuz body lifts are gay. lololol
EDIT: I see you have a body lift. No offence. lol. Lower cg and you know you wont have a problem with it if you leave it stock.
Old 06-10-2009, 04:24 PM
iamsuperbleeder's Avatar
who needs a hood anyway; pretty-up that SB Chev and show it off to the world
Old 06-10-2009, 04:29 PM
KVRunner's Avatar
I completely agree
Old 06-10-2009, 04:43 PM
waskillywabbit's Avatar
More hp to kill yourself with now?
Old 06-10-2009, 04:48 PM
Duelertoyota4x4's Avatar
http://www.toyotafiberglass.com/hood.htm
Some nice ones there
Old 06-12-2009, 05:52 AM
olharleyman's Avatar
3" Chevy 427 Corvette Cowl Hood Scoop graph it on the hood then cut out what you don't need under it that's what I am going to do for my 3.4 like this one.
http://cgi.ebay.com/ebaymotors/Hood-...Q5fAccessories
Old 06-12-2009, 12:48 PM
wheatus's Avatar
before you go cutting up your hood make sure you weld in some new supports before you cut. it will help your hood retain its shape and makes for a much better looking mod.
Old 06-12-2009, 05:45 PM
KVRunner's Avatar
If you are going to cut up a hood, I would get one out of a junkyard that you can cut on just in case you make a mistake cutting or something.
ashamsuddin
17
01-13-2023 03:17 AM
kawazx636
10-06-2021 03:03 PM
TheBFA
02-15-2020 06:55 AM
SpookyMulder
11-04-2015 11:56 AM
Davebarbier
11-03-2015 03:28 PM
Quick Reply: PU Hood Scoops / Aftermarket Hoods
