PS Pump Pulley -92 V6 4Runner
Old 06-05-2009, 07:12 PM
jasonbrink's Avatar
How do you remove the pulley from a 3.0 PS Pump? I got the nut off that holds it to the shaft no problem, but I can't seem to budge the pulley. Are there any tricks/tips to remove this thing?
Thanks,
Jason
8AhCK
Old 06-05-2009, 08:42 PM
RMA
RMA's Avatar
Check this thread out!!
https://www.yotatech.com/forums/f116...riteup-183622/
Old 06-06-2009, 08:24 AM
bugs1961's Avatar
Jason,
Use a pickle fork or a tapered pry bar between the housing and the hub of the pulley. A few taps and it should pop off. Don't put pressure on the pulley outside edge or it will bend. The pulley is lightly pressed on and rust will tend to seize it in place.
Bugs
Old 06-06-2009, 12:06 PM
TNRabbit's Avatar
That or a pully puller will work, too.
Old 06-06-2009, 03:15 PM
jasonbrink's Avatar
Wouldn't that bend the pulley?
PS- STILL not off. The worst part is this one has to come off to get the pump out to replace with my replacement pump, which also has the pulley stuck on it!
It's amazing how the "simple" things always take so long on these trucks!
Jason
Old 06-07-2009, 05:10 AM
bugs1961's Avatar
Here's an idea. Cut a 2x4 about a foot long and then cut off the end at a 45 deg or greater angle, widthwise. Then you could cut out a slot about an inch wide lengthwise and you have a thick pickle fork. Try tapping that over the shaft. No idea if this would work and I'm sitting in an airport right now so I can't look at my truck and see if it would. Should only take a few minutes with a circular saw.
I've had good luck with a regular ball joint pickle fork placed right next to the shaft between the pulley and housing. But a 2x4 would act on both sides of the pulley and may work better. Good luck,
Bugs
Old 06-07-2009, 05:53 AM
Ardent's Avatar
Does the new pump have a new pulley on it? You can remove and install these pumps with the pulley still on. I did it on my '93 because I couldn't get the pulley off.
Edit: https://www.yotatech.com/forums/f116...g-pump-182989/
Old 06-07-2009, 06:29 PM
bugs1961's Avatar
Any luck, Jason?
Old 06-07-2009, 07:16 PM
jasonbrink's Avatar
Originally Posted by bugs1961
Any luck, Jason?
It rained here most of the day today, and I'm doing this in my driveway, so I didn't even look at it.
I'm going to go to autozone tomorrow and pick up a pickle fork. All the pry bars I tried (and I have like 20 of them in various sizes) didn't work. It didn't even budge last night.
BUT, tomorrow is another day...
I will post back.
Take care Bugs!
Jason
ladybugRC
458
08-21-2020 10:41 AM
rubrsidedwn
07-07-2016 07:28 PM
nvwiggins
13
06-16-2016 03:05 PM
Rcbc92
09-26-2015 03:00 PM
some drunk guy
09-04-2015 11:55 PM
Quick Reply: PS Pump Pulley -92 V6 4Runner
