Problems later with adding a lift?
Old 09-13-2009, 08:53 AM
littleblue4runner's Avatar
I have been lookin at a 2 inch lift kit from toytec and its a add a leafs in the back and a spacers in the front for $239. If I was to do it, will I have steering problems later down the road?
Old 09-13-2009, 09:02 AM
waskillywabbit's Avatar
No.
Old 09-13-2009, 09:03 AM
874runnersr5's Avatar
Spacers in the front as in ball joint spacers?
if so, youll need a alignment after you install em
Old 09-13-2009, 09:09 AM
could i do it myself at my house? yes ball joint spacers.
Old 09-13-2009, 09:13 AM
Install the 2" lift. Yes.
Alignment. Probably not.
Old 09-13-2009, 09:17 AM
Jay351's Avatar
depending on what kind of add-a-leafs they use your leaf packs might get worn out.
Mine are turning into a M shape... after bout 2 years of running a poocomp short style add-a-leaf (including a few intense wheelin trips!)
Old 09-13-2009, 09:21 AM
so get it? or would you get something different is you were doing it to your truck?
Old 09-13-2009, 09:30 AM
really?
Old 09-13-2009, 09:40 AM
what to ball joint spacers really do?
Old 09-13-2009, 10:01 AM
Jay351's Avatar
THey are installed above the upper balljoints, they lower the spindle and lower control arm 1.5" (or however tall the spacer is).
This allows for added travel, clearance and ride comfort without really doing much.
for the rear I would put new springs in, but its not cheap.
A long style add-a-leaf would be okay.
Old 09-14-2009, 03:03 PM
why does it not mess up the steering?
Old 09-16-2009, 06:43 PM
abecedarian's Avatar
It does mess up steering. BJ spacers will push the lower arm down without affecting the upper arm, causing the lower arm to pull the lower BJ inwards, pulling your camber towards positive, and will also effect your caster and toe, as well as affecting how your camber, toe and caster all change as a wheel cycles from full extension to compression and back.
And for the 'kicker', BJ spacers will make your vehicle ride higher but will not keep the suspension from compressing any more than it did before... so if a 31" tire rubbed w/o the spacers, it might clear with them but a hard bump will make them rub as if the BJ spacer wasn't there.
Flying91
45
04-11-2024 04:39 PM
Eggslinger
06-08-2019 03:32 PM
09-04-2015 09:27 AM
Yota.Jay
07-23-2015 08:08 PM
timmJ
07-07-2015 02:01 PM
Quick Reply: Problems later with adding a lift?
