Problems with front sway bar
Old 03-25-2009, 07:38 PM
WillRadford's Avatar
So I had both sway bars removed on my 91 4runner V6 manual trans and Im getting ready to sell the vehicle now so I need to put the sway bars back on. Problem is I can't get the front sway bar back on correctly! I got it on with the frame mounts and the control arm mounts secure, but the problem is that the sway bar is rubbing on the front drive shaft! Something is screwed up and I can't figure it out. Has anyone else run into this problem before?
Old 03-25-2009, 07:40 PM
iamsuperbleeder's Avatar
flip it over
sounds like you've installed it bass ackwards
here's a pic showing how it installs; this is the exact orientation it's in when bolted up
take close note to the bends and dips in it
Ardent's Avatar
The brackets that hold the bar to the frame are probably turned around. It sounds like they're probably pushing the anti-sway bar forward into the ds. Try flipping those brackets around or switching which side they're on.
Old 03-26-2009, 05:18 AM
Ya, Im a dumb ass. As soon as I wrote this post I went back out to the garage and realized that it needed to be flipped around AND its not supposed to go on top of the drive shaft. The rear anti sway bar DOES go over the drive shaft but the front one does NOT. So, obviously it was an easy fix. One of those things where you spend 60 minutes doing something that should have taken 10. Thanks guys.
Old 03-26-2009, 09:18 AM
be happy that's all it was
I was right
lledwod
08-30-2016 01:03 PM
shisha1999
03-16-2016 12:25 PM
09-04-2015 09:27 AM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: Problems with front sway bar
