Problem Starting
Problem Starting
Well thought it was the old starter in the 91 runner 3.0 went to oreiley and they said it was the starter bought a new starter and same problem click click battery is charged the selinoid on the starter is ingaging but no turning of the starter moter. any suggestions! Is there another starter relay or something that might be bad help this is a daily driver.
Thanks for the help.
mine did the same thing with Advance Auto starters, so i jsut forked out the extra money for a Napa starter and havent had any clicks from it yet. usually the advance starters would last abouot 2 months, this one has been in for about 3 and no clicking yet.
This just happened to me today. It wasn't the altenator, I was gettin 13.8 steady. And the batt is fine, sitting a little above 12. Come to realize when I jumped it, the main ground attachment on the battery was loose from when I installed my aux lights. So there was enough contact once the truck was running, but not enough to turn her over.
Just double check the most obvious stuff first, then get technical. It's much cheaper.
Similar thing happened on my Camry. Replaced the starter and she still wouldn't turn. The bolt holding the ground to the block had backed out and the cable was lose. Oh well, it's got a new starter that I don't have to worry about.
06-01-2021 01:51 PM
Regency
20
01-03-2020 07:43 PM
Jnkml
07-06-2015 01:20 PM
