Problem with diff drop!
Old 12-10-2010, 09:35 AM
PR_TRUCK's Avatar
Hello guys, i am new to this world. I am starting to do my mechanics so i am NOOB in this. I got the kit from 4 crawler and i install the swaybar spacer. When i get to the diff, i install the left spacer but the rigth one is imposible to align the hole from the frame bracket with the space. There is a trick or u guys have the same problem when installing? any tips?? Thanks
Old 12-10-2010, 10:56 PM
totally a bro
Staff
vital22re's Avatar
Don't tighten the bolt all the way. Just get the nut started on the threads. This way there will be enough play to get both bolts in and started.
Old 12-11-2010, 01:44 AM
gary96360's Avatar
yeah just get the threads started and stick in a crowbar to get the holes aligned
Old 12-12-2010, 02:50 PM
angrybob's Avatar
I just installed my front diff this morning and it has the drop spacers.
The above is exactly correct. Get both started first. You may even have to loosen the front mount to get it to wiggle easier if you are having alignment issues.
Sleaker
08-26-2020 06:03 AM
jerusry
10-19-2015 05:28 PM
shisha1999
07-13-2015 11:09 PM
TokyoD23
07-12-2015 06:01 AM
Jnkml
07-06-2015 01:20 PM
Quick Reply: Problem with diff drop!
