| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Problem with clutch/clutch pedal
#2 (permalink) |
It's most likely a leak in the hydro system.. First thing to do is check if you've got fluid in your clutch master cylinder.
__________________
http://www.22REturbo.net |
#3 (permalink) |
How many miles? The hydro goes out around 140-160K. I just gone done with mine. The master had no more fluid in it, just a lump of black goo. No leaks. It was working but the pedal was sticking to the floor sometimes. The pushrod was all the way out, too. The disk was almost to the rivets. 1/64" remaining.
#4 (permalink) |
i got a friend that has the same problem, except hes replace the master cly. and the slave cly. bleed the whole system many times and still can get the clutch to disengage.
__________________
JP 2003 Tacoma White TRD E-Locker, 3" toytec lift, 2" RB BL 10,500 milemarker, 32/12.50 BFG MT on black wheels UWS black toolbox, and working on more. 2007 fj cruser (moms) 86 4runner 22re auto 3" leafs 32bfg mts |
#5 (permalink) |
I'm pretty sure there are no leaks. I guess I should start by opening up the master cylinder?
#6 (permalink) |
Oh and it has ~155000k on the clock.
#7 (permalink) |
FFT:
If it still won't disengage, than the clutch is shot. If the disk is burrowed into the damaged flywheel or the disk is rusted (stuck) to the shaft at the spline than it won't disengage. Last edited by timebandit; 01-12-2007 at 08:02 PM. |
#8 (permalink) |
I just got done with mine at 145K. $1200 for new clutch kit and cylinders and labor. It it just too cold right now to be under there. And I barely have the time.
4813: It sounds like the master is bypassing or out of fluid by what your telling me. Last edited by timebandit; 01-12-2007 at 08:05 PM. |
#9 (permalink) |
By the time the clutch won't work, it's dry... Yea, you should start by checking to see if you have fluid.
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Clutch grinding, poor shifting, cracked clutch pedal bracket | T100NewMexico | 93-98 T100s | 10 | 09-22-2006 01:31 PM |
| Clutch pedal/clutch problem: help needed | p.m.coupe | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 03-04-2006 02:18 PM |
| Will the height adjustment of the clutch pedal affect the wear of the clutch? | YotaJunky | Maintenance & Repair Archives | 6 | 11-21-2005 08:03 PM |
| Clutch pedal return problem | io | Maintenance & Repair Archives | 3 | 07-09-2005 01:52 PM |
