Pro Comp Skid Plate
Old 12-28-2011, 09:11 PM
Bigyota1989's Avatar
Pro Comp Skid Plate
i recently purchased a pro comp skid plate for my truck because it looked empty up front ever since i installed my five inch lift. but the problem is that the skid plate seems to be about 1/2" too short. im gonna make mounting brackets to put it on but i just was seeing if anyone else has had this problem?
Old 12-29-2011, 09:00 AM
abecedarian's Avatar
you're putting a pro comp skid plate on a pro comp bracket lift kit, right?
I ask 'cause pro comp didnt make a 5" lift kit for the IFS trucks so didn't make a skid plate that size
otherwise, I suggest bolting up the front to the member behind the bumper, then the other end. I recently purchased one used (pro comp skid for pro comp 4" lift) and it didn't look like it would fit, but actually fit fine once it was "loosely" mounted and then tightened up.
Old 12-29-2011, 09:53 AM
scuba's Avatar
HOLY CRAP....
He.. He lives..
Old 12-29-2011, 10:37 AM
Originally Posted by scuba
HOLY CRAP....
He.. He lives..
now... back on topic.
Old 12-30-2011, 03:31 PM
well the 4-5 inch lift. and i have a rough country lift installed. and i bolted it up at the bottom and the bolts at the top crossmemeber were just a little off. i can make it work, i was just wondering if i should make a stink about this or just suck it up and mount it
Old 12-31-2011, 10:22 AM
the ProComp skid is specifically for their lift kit. Others use different means to accomplish lift that don't always play well together. ProComp went with drop brackets that were about 4" tall and didn't modify upper or lower arms. Rough Country, IIRC, went with about 3" bracket drops and supplied new upper arms that acted like BJ spacers and had to crank the t-bars to accomplish their lift.
You found out different mfrs do things differently when the bottom worked but the top didn't. I bet you could put bolts in the top and find the bottom doesnt work too- you probably tried.
If you can make it fit, I say why not? As long as it looks good and not redneck engineered- go for it.
Old 12-31-2011, 04:52 PM
Cyberman's Avatar
Rough Country doesn't replace the upper arms. It only has the drop brackets. Since RC didn't make a skid plate for their lift, I ended up having one fabbed. Soon, it's all going away for a solid front (finally).
Old 01-07-2012, 01:07 PM
well eff it then im just gonn amake it work
kawazx636
10-06-2021 03:03 PM
voiddweller
10-02-2015 07:47 AM
myotherrideisayoshi
09-29-2015 05:41 AM
Odin
09-26-2015 06:56 PM
AlexJet
09-14-2015 09:00 AM
Quick Reply: Pro Comp Skid Plate
