Pro Comp shock replacement
Old 08-16-2007, 03:30 PM
GlowinToyota's Avatar
So after I finally tracked down some replacement shocks for my 88 4runner with a 4 inch suspension lift, I was directed to these shocks:
http://www.4wheelparts.com/PPT5411T100423.aspx
I called 4 wheel parts and the guy said that they would work with a 4 inch lift application.
Is this correct? I haven't had the best of luck with people telling me one thing...
Are these shocks any good? I do more on-road driving with this truck than anything right now, but it gets the occasional off-road session.
Old 08-16-2007, 04:57 PM
Jay351's Avatar
I put on a set of procomp es3000 shocks, big improvment over the old stockers.
Great ride on and offroad.
plus you would be getting better ones to boot!
Old 08-16-2007, 05:19 PM
92whiteyota's Avatar
yea i just ordered the procomp es9000 shock and steering stablilizer...very excite!
Old 08-16-2007, 09:19 PM
olharleyman's Avatar
I have a set of these on my 90 4runner and I will say that they are a very nice set of shocks for the price.
They ride pretty well and the steering dampener works really well.
All in all you can't go wrong with these they are great for the money.
I have about 25-30 k on my 9000's but I did get a longer set up from the 4" lift because the 4" just kept bottoming out.
I got my lift from 4wp and just upgraded the shocks. IIrc the extended length on front is 26 1/2 rear is 29 1/2 work great on 4" lift kit.
Old 08-17-2007, 08:57 AM
sweet. thanks for the input guys.
Old 08-17-2007, 10:30 AM
TC4RNR's Avatar
do you have an angle grinder? you may need it if you're running withOUT front sway bar.
i just put in a pair of ProComp's in the front, ES3000 4" lift. take a look at your front suspension, there are 3 bump stops, one upper(for UCA) and two lowers. one lower bump stop is over the front, another lower in the back. ok, problem is the one in front, too close to the shock. remember the factory shocks have waay smaller diameter tubes. i had to remove the bump stop, then trim some metal off the bump stop housing to avoid the new shocks clipping with them.
i can take some pitures if you need.
oh, by the way, the ride is much betterwith ProComp's than the Rancho rs5000's i had on before.
Old 08-18-2007, 08:59 AM
I still have my sway bar connected. I've never really understood what it helps by disconnecting it, guess I've just never paid attention.
Old 08-18-2007, 09:25 AM
Tacotex's Avatar
If you're keeping the vehicle for 2 years or more, you might consider the Bilstein 5125s. They will out perform and outlast the procomps by far. I've also heard a lot of negatives about 4WPs, but have no experience with them personally.
Old 09-26-2007, 02:17 PM
So the idiot that I talked to told me to get the wrong ones, so when I cross-refrenced the numbers it came out wrong and I had to get the right number and give them to the sales guy.
They showed up today, with no cool colored boots. Were they supposed to come with the shocks? I got the steering stabalizer too. Install this weekend.
Old 09-26-2007, 02:21 PM
Toyvana's Avatar
Most shocks come with boots. I just sold my ES9000's and bought a set of Bilstein 5100 series.
Old 09-26-2007, 03:06 PM
TC4RNR's Avatar
for the ES3000 series shocks, boots are extra, $8/pair in my case.
Old 09-26-2007, 04:58 PM
mr toytech's Avatar
i ordered my es9000's through 4wheel parts and mine came w/ the boots. they even asked me what color i wanted. and by the way i love them so far.been on the truck since the begining of summer.
Old 09-28-2007, 08:44 AM
See, they asked me the same thing when I firsted started to order them, but didn't think the guy knew what size they were.
mskalmus
05-28-2017 07:51 AM
TURBOrunnerNM
07-22-2015 11:01 AM
rbh261
07-13-2015 12:04 PM
akaphilly
07-09-2015 02:34 PM
tpd143
07-07-2015 09:06 AM
Quick Reply: Pro Comp shock replacement
