Pro comp coils?
Old 02-19-2012, 06:10 PM
FuelforWar's Avatar
Pro comp coils?
So I installed some pro comp coils with 4in of lift this prior summer. they seem to have done well, but i've noticed a sag on my passenger side steadily getting worse. Now the passenger side is sitting 2-3in lower than the drivers side. Is this due to an incorrect panhard bar or have I just make a bad purchase on these. Input heavily appreciated.
Old 02-19-2012, 09:39 PM
FuelforWar's Avatar
....any info? is there anything other than the coil that will make this side sag so badly? there only a few months old.
Old 02-21-2012, 02:38 PM
FuelforWar's Avatar
Well I swung by 4wheelparts today (where i bought the coils), They called procomp and there still under warrenty so I'll have a replacement set this friday. Hope this fixes the issue.
Old 02-21-2012, 03:09 PM
Levinz11's Avatar
You will def. need to drop the panhard bar with that much lift.....if you didn't the first time. Is the passenger side wheel sticking way out?
Old 02-21-2012, 04:18 PM
FuelforWar's Avatar
Panhard bar is installed. But i'm not sure if its too long. i was told this shortly after installing them last time. Was told to measure from ground to bolt on both and the difference was the size I needed. Well I have 7" of difference, so i bought a 6" panhard drop bar. well now with that side of the truck sagging, its not level anymore. Should have I only gone with a 4" drop since my coils were 4+ over stock?
justdifferentials
14
06-11-2017 08:36 PM
voiddweller
10-02-2015 07:47 AM
the_supernerd
10-01-2015 09:20 PM
myotherrideisayoshi
09-29-2015 05:41 AM
Odin
09-26-2015 06:56 PM
Quick Reply: Pro comp coils?
