power window on passenger side dont work
hey there. my power window on the pass side dont work. i had an extra switch so i swapped in and the window still didnt work. so i took apart the door and pulled the wire that goes to the window motor and put 12v to the motor. it didnt work so i switched the pos and neg wires from a battery. after a min trying the window went down and up. so i put the switch back on and nothing worked. so i took off the switch again and put 12v again to the motor and nothing worked. so im thinking maybe the ground is rusty if it even has a ground. any help is greatly appreciated
Make sure all the connections are corrosion free, they like to get nasty in those doors..
IF it still is no good, go get a window motor from a 4runner $10 if not less..
Jesus! You could get one shipped from the mainland for less then half that.
If you seriously can't find one around there for a good price, pm me and I might be able to ship one to you.
I believe that many Toyota window motors are the same....like a Camry. Check the part numbers first.
Hint: if you can, grab a rear passenger side one from a sedan - it will have the least amount of use
Mine stopped working years ago in my 4runner and I just replaced with a manual one....wish I'd known then what I know now :/
yourrealdad
7
07-21-2015 08:53 AM
