Power Window/Locks quit working..
Soo Ive got a 92 4Runner
3.0L V6
5 Spd Manual
4WD 4Dr
430,000 km
My rear window quit working a few weeks back, pushing the swtich would not draw power on the volt gauge so my guess was just the switch.. not a problem, its nearly winter and I can go a few months without.
However, just last week, ALL the power windows and locks are entirely unresponsive.
I cant find a fuse that is bad, and after some reading I thought there was supposed to be a window and lock relay below the steering column somewhere- Which I cant find at all..
Can anyone help a guy out? Thanks!
3.0L V6
5 Spd Manual
4WD 4Dr
430,000 km
There's a "door lock control relay" above the fuse box. http://web.archive.org/web/201102052.../7powerwin.pdf But unless you're an electrical genius, you don't want to mess with it. And it's not likely to be your problem.
The most likely location (and the first place to look to find the problem) is the driver's side door lock switch. Using the schematic above, pop out the switch and check for the correct voltages. That will point you to the problem.
PNW94Runner
09-29-2015 02:55 PM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
09-24-2015 03:30 PM
jacked_72
09-14-2015 03:31 PM
