Power Steering and Tachometer
Old 05-02-2007, 12:10 PM
TastySalmon's Avatar
I bought my first Toyota last night. It's a '92 but it has no power steering. This doesn't bother me much since my current vehicle has no power steering either. The person I bought it from said that it's possible to take the pump, reservoir, etc. off of a wrecked truck. Has anyone done this before and how time consuming is it?
Also, since it's a bottom-end truck it also has no tach. I've seen single unit tachs for sale in Shucks but I don't know how to hook them up. Can someone give me some advice on this also.
Thanks
Old 05-02-2007, 12:17 PM
Farmerunner's Avatar
Any aftermarket tach that you buy will have detailed instructions on how to install it in your truck. I put one in my 94 F-150 and it was very simple. As long as you have a basic electrical knowledge you will be OK.
Your other option would be to go to a salvage yard and buy a whole dash for your truck, to keep it stock looking. I am sure that there is all kinds of information on this site to help you with that, search for it and you will find.
Old 05-02-2007, 06:21 PM
MMA_Alex's Avatar
not worth the time to put in powersteering unless you're a grandma, or a rockcrawler. I actually prefer not having power steering personally.
aftermarket tach's are fairly easy to install as long as you can follow directions, and crimp wires. I was considering getting one, but couldnt find a decent place to mount it, or a decent sized tach for cheap so i just ended up getting used to driving by sound. The problem i found with all the store tach's was that theyre all like 6" diameter with a giant ricey shift light.
There is a fair amount of info on here about swapping consoles, but if you're not used to doing electrical work its probably beyond your capabilities because a lot of things arent compatable between the two, and a lot of little things need to be dealt with.
Old 05-02-2007, 06:30 PM
dmon's Avatar
my dad did his. took maybe 3hours. deponds what you are doing. if your gettn a rebuilt pump its gonna take about 3. if your just gonna get the rebuild kit, its longer, and u have to take the pump appart. for a truck, i think u should do it. its dangerous when your stopped, and trying to turn your wheel all the way to the right or left. but good luck with your problems
Zpd426
01-02-2016 01:15 PM
delmert
09-30-2015 04:34 PM
Up&Down
08-11-2015 10:04 AM
toyoterferdayz
Diesel Swaps
07-27-2015 05:25 PM
gmonnie123
07-26-2015 02:44 PM
Quick Reply: Power Steering and Tachometer
