Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
Power steering pump questions
Okay, so after having my power steering pump pully come OUT of the pump and almost into my fan the other day, I have installed a used pump I bought last week.
I got everything hooked up like its supposed to be but I have a question or two for you guys.. First. when I removed the old pump, a little fluid came out of hte lines.. Nothing major, perhaps 1/4 a quart. It did dump some fluid out when the pulley came out of the pump the other day. Can I assume there is still some fluid inside the system? Second. Can I just fill up the new (used) pump, install my belt and call it good? Or should I jack up the truck, and cycle the steering from lock to lock a few times then check the fluid again? I really don't know much about the power steering stuff.. Just how it bolts in ![]() Thanks guys (and girls)
__________________
91 Pickup - xcab - 5sp - 3.0 - sr5 - 4x4 - 230,000kms |2.25" catback w/ magnaflow cat + glasspack | Weasy2k cams | Aisin manual hubs |Diff breather mod | Marlin HD clutch |3" BL | es3000's |2" AAL |1.5" bj spacers | ISR | Alpine headunit | 4" Infinity fronts/5" rears | 4.88's |Rear lockright | 33x12.50" BFG M/T on 15x8" steelies |Hella 500's |4" reverse lights| Grant GT |Downey idler arm brace|hella E-codes| Marlin armor | %100 Amsoil synthetic http://www.cardomain.com/ride/2572486 |
| Sponsored Links |
#2 (permalink) | |
you don't necessarily have to jack it up, but do cycle the steering back and forth from lock to lock and hold it a few seconds at each lock. That should purge the air from the system. check the fluid in the reservoir after each left/right cycle so that you don't risk introducing more air into it.
__________________
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| power steering pump | 85.5Yota | 86-95 Trucks & 4Runners | 1 | 05-04-2008 11:09 PM |
| Power steering pump 3.0 | Shock5 | 86-95 Trucks & 4Runners | 12 | 10-17-2007 02:59 PM |
| 93 4Runner Power Steering Pump and Water Pump/Thermostat Replacement | Lucky_13 | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 11-17-2005 09:37 AM |
| 93 4Runner Power Steering Pump and Water Pump/Thermostat Replacement | Lucky_13 | Maintenance & Repair Archives | 1 | 11-16-2005 04:26 PM |
| Power Steering Pump | tpg013 | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 03-02-2004 09:01 AM |
