power steering pulley
Old 09-29-2008, 12:42 PM
j
j's Avatar
i know that this has come up several times on this board BUT i've tried all the recommendations and it will not come off. Can i keep it on and work around it? thanks
Old 09-29-2008, 12:56 PM
jason191918's Avatar
Can you leave it on? That would depend if you are changing the oil or taking off the pump.
Old 09-29-2008, 02:02 PM
Matt16's Avatar
To remove it, you need a special tool called a "pulley puller" or something. Mines bent and wobbles from my trying to get it off without such a tool.
Old 09-29-2008, 02:26 PM
Team420's Avatar
x2... gotta have the puller, and not the jaw type.
Old 09-29-2008, 03:03 PM
Matt16's Avatar
or the vise-grip type.
Old 09-29-2008, 03:09 PM
j
j's Avatar
sorry, forgot to mention, I'm doing a head gasket.
Old 09-30-2008, 05:02 AM
GSGALLANT's Avatar
I'm assuming you are working on a 3.0L... it helps if you tell us what you're working on when you ask for help...
If so, then yes you can remove the PS pump to do the HG without removing the pulley.
Old 09-30-2008, 05:04 AM
Team420's Avatar
^^ Really?? I would love to know how... I tried that when I was replacing my ps pump, and couldnt get the pump out because of a bolt behind the pulley. I loosened the bolt, but couldnt get it out w/o removing the pulley.
Old 09-30-2008, 07:14 AM
j
j's Avatar
working on a 3.0. So i got it off last night but had to remove the pump while it was still attached to the bracket. seemed alot easier than taking off the pulley and you have to take it off later in the fsm anyways. I don't see why that isn't the recommended way to do it. just took off a nut and three bolts instead of messing around with the pulley.
Old 09-30-2008, 08:27 AM
wardriver's Avatar
X2 - did the same thing not too long ago. I didn't have any issues keeping the pulley on while doing the swap - just unbolted the whole pump.
delmert
09-30-2015 04:34 PM
Up&Down
08-11-2015 10:04 AM
toyoterferdayz
Diesel Swaps
07-27-2015 05:25 PM
gmonnie123
07-26-2015 02:44 PM
yoterr
07-24-2015 04:29 AM
Quick Reply: power steering pulley
