Power Steering Leakage
Old 09-17-2008, 10:34 AM
YotaJake's Avatar
Hey guys,
I have a leak at the rear seal of my power steering pump. Can I just take off all the bolts and install a new rear seal with all the lines still attached. Is store brand ATF ok, such as Advance Auto or Walmart? Also, I have a leak at my input shaft of the steering box. I recall a part number for just the seal, but can't find it anymore. Does anybody have that part number? Is that a tough job to do?
Old 09-18-2008, 09:31 AM
San Martian's Avatar
I am having some similar power steering leakage issues/ noise when turning at slow speeds. Do I need a new pump? is a full replacement gonna be a PITA/ Expensive? Any help is appreciated
Old 09-18-2008, 01:30 PM
anotherjeff's Avatar
If the pump is leaking, take it off and rebuild it on the bench. Rebuild kits are widely available.
Old 09-18-2008, 02:22 PM
slowheelin's Avatar
I just replaced mine. Pretty straightforward job and it only took a couple hours. One thing you don't want to do is break the thing the vacuum lines connect to. I did and they're expensive......
Zpd426
01-02-2016 01:15 PM
delmert
09-30-2015 04:34 PM
Up&Down
08-11-2015 10:04 AM
toyoterferdayz
Diesel Swaps
07-27-2015 05:25 PM
gmonnie123
07-26-2015 02:44 PM
Quick Reply: Power Steering Leakage
