Power Steering Hose Alternative.
Old 01-27-2009, 10:29 AM
bigdaddy87547's Avatar
My power steering line has been swelling and leaking fluid. Rather than purchase a hose for $50 + could I go to one of the hydraulic shops around and have them re-crimp a new piece of hose. Does this seem like a good alternative or does this make me sound too cheap?
Old 01-27-2009, 10:37 AM
mt_goat's Avatar
If you do that make sure the clocking is correct on the fittings. Those hoses don't twist at all.
Old 01-27-2009, 10:39 AM
Thanks for the heads up. The hose that is swelling goes from the P/s pump to I believe is the abs actuator beneath it.
Old 01-27-2009, 10:50 AM
mt_goat's Avatar
Yeah that's the way my old 3.0 PS hose was.
Old 01-27-2009, 11:39 AM
1styota4X4's Avatar
I had mine rebuilt at a shop they did great and was a better fit...call before you go they might want to look at the rig/hose before hand they needed to do that on my AC hose
Old 01-27-2009, 01:16 PM
PCE91V64x4's Avatar
take it with you and tell them to copy it. They could always make it a little longer if you need some flexibility.
Old 01-27-2009, 02:46 PM
The folks at the shop should be able to recommend the right type of hose for my application, correct? It would probably be a good idea to add some dye to my power steering (atf) and black light it to see if it leaks anywhere else. What do yall think
Old 01-27-2009, 03:26 PM
abecedarian's Avatar
ATF already has dye: it's red. I wouldn't add anything to the fluid.
And yes, the hydraulic shop will know what hose to use... and will probably recommend a hose that far exceeds what you need.
Old 01-27-2009, 06:46 PM
I'll keep you guys posted. I still cant get over how knowledgeable you toyota owners are.
Old 01-27-2009, 06:51 PM
Most of it is common sense.
Old 01-27-2009, 07:38 PM
waskillywabbit's Avatar
An OEM high pressure side ps hose is just a tad more than $50 at the dealer...most start at about $300 and get stupid high from there.
Get one from a junkyard as they are all the same 86-95 on all the Toyota 4x4s.
Low pressure side is just local auto parts hose and some hose clamps.
Old 01-27-2009, 09:15 PM
If it was common, everybody would know this.
montanatruck
02-26-2017 07:07 AM
terminator
07-27-2015 07:13 PM
keithporter83
07-24-2015 07:37 AM
whereAreMyPants
07-22-2015 03:32 AM
jon.r
07-11-2015 03:34 PM
Quick Reply: Power Steering Hose Alternative.
