Power Steering box issue
Old 04-26-2009, 12:06 PM
RaginYota's Avatar
Well I walk out to the yota this morning, and I see power steering fluid everywhere. I though ok, I need to get another one, no biggie. After removing the air filter box, I noticed there is a bolt that has come loose. So I put it hand tight... but I also noticed that on top of the screw it has a spot for a slotted screwdriver. Seems to me that it is some type of adjustment screw???? Anyone know what this actaully does?? or how to adjust it??
Here is the bolt I am talking about..
Thanks in advace!!
Jeremy
Last edited by RaginYota; 04-26-2009 at 06:54 PM. Reason: Inappropriate language removed
Old 04-26-2009, 01:56 PM
Flash319's Avatar
Not 100% but I know on chev boxes it sets the pre-load on the gears. If you crank it in the steering will get tight (won't want to come back to center on its own), if its loose you will get backlash in the gears. Someone else may be able to comment further.
Old 04-26-2009, 02:51 PM
desert-rat660's Avatar
i think it adjusts the freeplay
Old 04-26-2009, 02:58 PM
fdp101452's Avatar
Yes it adjusts the free play. In other words, it adjusts how much movement you have in your steering wheel from side to side before it starts moving the tires. The screw is the adjustment and the nut locks the screw. Screw the screw in until you have the freeplay you want and lock it with the nut...regards...Rick
Old 04-26-2009, 06:55 PM
RaginYota's Avatar
Awesome thanks alot!!! Now I understand why it rattled when I was going over bumpy terrain.. I could never figure out how to stop it.. now I do... Thanks again!!!
jon.r
07-11-2015 03:34 PM
nick b
07-11-2015 04:38 AM
crashburnoveride
07-10-2015 06:39 AM
skoti89
07-08-2015 12:05 AM
Quick Reply: Power Steering box issue
