Power Mirrors are not working - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-16-2006, 11:38 AM   #1 (permalink)
My power mirrors are not working and the fuse is good. Does the switch go bad very often?
__________________
91 4runner SR5 V 6 3.0 190,000 5 speed 32 x 10.5 Manual Hubs Otoe County Nebraska
jjenks0 is offline
Old 03-09-2007, 08:00 PM   #2 (permalink)
Jjenks0,
Did you ever find out why your mirrors quit working? I have the same problem but can't figure it out.
BTW, which fuse did you find controlled the mirrors? I replaced the switch but that didn't help.
I have a 93 4runner.
Thanks
dirkdoesdirt is offline
Old 03-10-2007, 04:10 PM   #3 (permalink)
leebee's Avatar
you may want to check you wires going through the door to the body for breaks.
lee
__________________
93 sr5 v6 auto, 4x4
Photos http://s866.photobucket.com/albums/a...albumview=grid
there are quite some attractive ladies on here with Toys. (compliments of ironmike)
ifsc 3(.0)
http://tlca.org
www.of4wd.com
www.sontt.com
leebee is offline
Old 03-16-2007, 07:04 AM   #4 (permalink)
mirrors
I got every tore apart last night. Door panel took the mirrors apart. Just a hint when taking the door panel off you may think that by taking the screw out of the door handle cavity it will pull off but you must slide the door handle assembly towards the front of the vehicle as it has hooks.
Any way by putting using a test light I grounded the clip on the door hinge roll pin and touched the pointed end to various connections on the back side of the switch. I had power on and was holding down on the switch in vaious positions. I did get the motors to spin. I am thinking that it may be a ground wire or something. The schemtics I have in my haynes does not show power mirrors. I hope this weekend to trace the wires and see if I can find a broken one.
__________________
jjenks0 is offline
Old 03-16-2007, 09:28 AM   #5 (permalink)
GSGALLANT's Avatar
My power mirror wires were cut in half by the small piece of metal that slides into the door between the two hinges and keeps the door from "over-opening" (hope that's clear). The wires were loose inside the door, and apparently got snipped by that sliding piece.
Also, for my power locks, I had a wire that broke inside the rubber hose section where the wires go from the door to the body (like leebee said). Only the wire itself was broken... the wire insulation was still intact, which made it really hard to find the problem. That problem was intermittent... every once in a while, I would open the passenger door, and when I got it halfway open, I'd hear all the door locks click to the open position. It got really annoying until I took the time to tear it apart and track down the problem.
__________________
2002 4Runner, Auto-A340F, 3.4L, 4.30 Gears
TJM T15 Front Bumper & Warn M8000, 4xInnovation sliders, Sonoran Steel 1.2 Lift, Toytec LCA Skids, Tundra Brake Upgrade (231mm), Extended rear diff breather, Deckplate Mod, Andymod, Dual batt setup with Optima blue top aux battery, Hardwired 1000W inverter, Aux fuse box, Full time power to 12V plugs, Yaesu FT7800R Radio, "4-air" system for airing up/down tires.
2004 Camry LE - stock (and will stay that way)
1993 4Runner has been sold
GSGALLANT is offline
Tags
4runner, mirror, mirrors, power, troubleshoot, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Power mirrors sts2usnss General Electrical & Lighting Related Topics 2 03-09-2007 07:58 PM
Power Mirrors Red90sr5 86-95 Trucks & 4Runners 1 03-07-2007 10:58 AM
No power windows, mirrors or locks...??? Denk 86-95 Trucks & 4Runners 2 03-04-2006 03:58 PM
No power locks, mirrors or windows...??? Denk General Electrical & Lighting Related Topics 0 03-02-2006 05:55 PM
Power side mirrors for 3rd gen KZN185W 95.5-2004 Tacomas & 96-2002 4Runners 5 07-24-2004 03:51 PM
2009 InternetBrands, Inc.
