pouring oil. 86 22re
Old 06-30-2010, 10:16 PM
502yoda's Avatar
i have an 88 pickup with an 86 22re motor. so i basically built this motor from the ground up. the head was warped so i replaced it. got everything back bolted down to torque specs and it was all good till i tried to fire, now oil appears to be pouring from between the head and block at the front of the intake manifold. any help and or suggestions are appreciated. would it be easier to fix this or just swap in a 350?
thanks,
Brandin
Old 06-30-2010, 10:29 PM
Staff
Terrys87's Avatar
Fixing it would be so much easier. My guess is when you put the timing cover on you tweaked the head gasket or another gasket. It is a mistake I made before.
Old 06-30-2010, 11:01 PM
502yoda's Avatar
alright ill tweak that around later today. thanks for the quick reply.
Colington
03-08-2020 09:51 AM
JaredL
03-28-2016 09:08 PM
09-04-2015 09:27 AM
AppalachianOffRoader
08-12-2015 12:55 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: pouring oil. 86 22re
