Post timing belt issues?! - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 06-20-2006, 06:59 PM   #1 (permalink)
mtrdrms's Avatar
So I just replaced the timing belt and water pump on my 89 4runner 3.0 5 spd and some funny things are happening. Now I only took it around the block but in that short time I ran into some issues. First the idle seemed very erratic. It was jumping from 1800 to 1000 and back. Once that seemed to settle down the truck began to overheat. I limped it home and now it sits in the driveway cooling off. Now while all this was going on it did run and drive just fine. It was not down on power or accelerating abnormally. I was wondering if anyone had experienced this before? I spent like 5 hours doing this job and I sure as hell dont want to take it apart agian.
__________________
89 4unner 3.0 5 speed
98 Tacoma 2wd, 2.4, AT, 225k
71 FJ40 Project
I have already searched.
mtrdrms is offline
Old 06-20-2006, 07:11 PM   #2 (permalink)
mr toytech's Avatar
sounds to me like you probably got an air pocket in the coolant system.
__________________
my truck new
my truck now with TRD wheels and exhaust
93 toyota
3.0 manual trans.
jeeps are so cute even barbie has one!!!
mr toytech is offline
Old 06-20-2006, 08:03 PM   #3 (permalink)
snap-on's Avatar
Send a message via AIM to snap-on
second the air pocket and or bad thermostat.
hows your timiming?
__________________
94 EX cab, 5speed, V6, locked, ARB bar, NWOR headers
92 4runner, auto, V6, OME suspension, Downey headers
snap-on is offline
Old 06-20-2006, 09:17 PM   #4 (permalink)
Third on the air pocket, mine did the same thing until I topped off the coolant level.
__________________
92 2wd extracab, 22RE, auto, 16" Mustang wheels, 225x16 BFG Supersport, antisway bars, KYB shocks, 01 4runner buckets, Grant wheel
86 4runner SR5, 22RE, 5 speed, Sold
90 extracab DLX, 3.0, 5 speed, Sold!
nmtoy is offline
Old 06-21-2006, 04:36 AM   #5 (permalink)
mtrdrms's Avatar
Would that account for the erratic idle? Maybe the water pump wasnt facing any resistance and therefore put less drag on the driveline? Any way I will post up any changes this afternoon.
__________________
71 FJ40 Project
mtrdrms is offline
Old 06-21-2006, 04:42 AM   #6 (permalink)
TNRabbit's Avatar
Erratic idle could be from your temp sensor not reading right since you probalby didn't have water flowing through it. The ECU bases a lot of adjustments to fuel/timing by the temp sensor.
Let the engine warm up with the radiator top off, then add water/coolant until it tops off (you should see the water flowing thru). Cap it, add some to the overflow, and take it for a test drive...
Let us know how it goes!
__________________
TNRabbit
Stock '94 DLX XtraCab 4x4 5 spd, Newly Rebuilt 3VZE, 17" 2006 Alloy Wheels, 228k miles, AISIN Hub Swap
3.0 Rebuild Thread: http://www.yotatech.com/f116/crap-he...-ghost-108156/
Quote:
Originally Posted by Junkers88 View Post
Like the good book says "you can give a man a Toyota and he will wheel for a year, you can teach a man Toyota and he will wheel for a lifetime."
yotatech 3:16
TNRabbit is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
timing belt issues budro 86-95 Trucks & 4Runners 3 05-19-2007 05:12 PM
3.4L Timing Belt Issues thefallman 95.5-2004 Tacomas & 96-2002 4Runners 4 08-20-2006 10:03 PM
ps pump belt install issues fatdudesurfin Maintenance & Repair Archives 8 05-09-2005 06:37 PM
engine belt/timing belt replacement question gomezza Maintenance & Repair Archives 2 04-11-2005 03:48 PM
timing belt joe d95 95.5-2004 Tacomas & 96-2002 4Runners 4 03-27-2004 10:31 AM
2009 InternetBrands, Inc.
