possibly bad tps?
possibly bad tps?
Recently, my toyota pickup (3.0 v6) has been idling very poor. It idles very low like it wants to die. When it is doing this, i can see the plunger on what i think is the dashpot moving back and forth? The idle will also smooth out at 1500rpm if i remove the vacuum line going to the dashpot. The last problem is when i hit the gas anymore than about 1/4 throttle, the rpms just drop like it wants to die. Anything under 1/4 throttle acts normal though. The only thing i could think of is a bad tps? Does this sound plausible? I went through some of the resistance checks on it, but the problem doesnt happen until the throttle is opened more than 1/4 throttle and i dont have access to an oscilloscope to check the full range of the sensor.
Here are some pictures of what i am talking about
This is the plunger that was moving back and forth during the terrible idle
And when i removed this vacuum line it idled smooth at 1500 rpm
you can check the resistance across the TPS using a cheap multimeter.. I used my analog multimeter yesterday to adjust my tps.. it worked great..
here is the thread https://www.yotatech.com/forums/f116...stment-197474/
It has a good link within the thread to adjust the TPS..
I does sound the TPS is possible cluprit to your problem, but I have no experience with the 3.0..
