Possible Transmission Issues - Let's play online diagnosis!
Old 03-12-2009, 06:04 PM
waskillywabbit's Avatar
91 22RE PickUp 5 spd
1st is fine
2nd is fine
3rd is fine
4th grinds and you can put it in 4th if you force it
5th is fine
In any gear when you let off the gas and let it slow down there is a distinct rumble from the tranny tunnel that sounds just like the same noise as a bad u-joint on the front driveshaft (if it were bad and the vehicle were in 4WD).
That is not the problem, just the same kind of rumbled noise it makes.
Anyway, just looking for ideas.
Old 03-12-2009, 06:08 PM
Staff
DeathCougar's Avatar
Sounds like the syncros in 4th are toast, or the bearing for 4th has given up.
4th gear usually isn't problematic on the 5speed toyota trannies though. However, if the trans was rebuilt previously, they likely didn't do anything about 4th gear parts, and it may have failed.
Old 03-12-2009, 06:11 PM
What about the rumbling roaring noise in deceleration in each gear? It is right there under the tranny tunnel.
I told him we could put in a new "used" one for peanuts, just trying to figure out what is wrong with this one and if it is worth tearing into.
mskalmus
05-28-2017 07:51 AM
Hamonacracker
07-17-2015 08:33 AM
jjrbus
07-17-2015 07:06 AM
Poncho0206
07-10-2015 06:21 PM
Coreyr384
07-10-2015 11:13 AM
Quick Reply: Possible Transmission Issues - Let's play online diagnosis!
