Possible newbie gear question
In the process of deciding which gears I want for my rig. I'm thinking 5:29 just because I love low gears. My question is, can I use my stock third member that currently has 410 gears and replace the ring and pinion with the 529? Just covering my bases before I get this all done.
You can reuse your current 3rd members and just re-gear them. The only one's you can't re-gear are the Toyota factory 4.88's. 5.29's are perfect for 35's. I have run 5.29's and 35's on many yota's, all with 4cyl.
^x2
Youll need a new crush washer, which should come in a bearing/install kit. Or its a great time to switch to a solid pinion spacer. Tad harder to set up, but wont loosen over time. Good time to add a locker too, you know, while youre in there.
http://www.4x4wire.com/toyota/tech/crush_sleeve/
TG sells the solid spacers
Stuarrt
04-19-2016 09:49 AM
