possible blown rod bearing
Old 02-23-2011, 07:45 AM
dirtpro06's Avatar
so yesterday my '86 runner (22re with an auto) developed an increasingly loud knocking noise timed with the engine revs and dies quickly as soon as i take my foot off the gas. I had a similar experience with a neon and it was a blown rod bearing. any chance this is anything less?
thanks guys
Old 02-23-2011, 08:01 AM
xxxtreme22r's Avatar
can be timing chain or valve lash off. But anything short of a video with sound is a guess.
FYI a slight rod bearing noise in my truck started only when starting the truck, at higher revs and when I would come off the gas when shifting though not go away when I come off the gas. Had this for 5,000 miles and who knows how long before that as I had just bought the truck, changing the timing chain didn't get rid of it and spun the #4 rod bearing.
Old 02-23-2011, 08:18 AM
blake.nemitz's Avatar
probably broken timing chain guides and your getting chain slap, as soon as you let off the slack is taken out on that side on wind down and it goes away, check that first easier to fix than a spun rod and usually a spun rod will knock on decel too
Old 02-23-2011, 08:59 PM
yotarover's Avatar
at least your not like me with a hole in the driver side of the block with 3 broken rods
Old 02-23-2011, 09:00 PM
yotarover's Avatar
broke 1 but i still had to limp it to a store to call a tow truck then broke the other 2
Old 02-23-2011, 10:20 PM
skoti89's Avatar
timing chain is more of a rattle when mine went bad...?
Then when my rod bearings went, it was definitely a knock. more high pitched of a knock though
Old 02-24-2011, 01:41 AM
axleman's Avatar
knocking sounds can be deceiving, if maybe your knock has a low growl to it it very well could be u joints or incorrect pinion preload.I almost replaced my whole bottom end once a long time ago before an old timer brought this to my attention. What i had thought was a couple of bad rod bearings or excessive endplay was only ujoints.
Old 02-24-2011, 04:39 AM
so did you pull the vavle cover and check the chain?
Old 02-24-2011, 06:01 AM
skoti89's Avatar
that is true. After my rebuild, I started hearing a clanking noise only when clutch release and giving it gas.
I was so screaming mad I couldnt believe it...turned out to be u joints lol
Old 02-24-2011, 04:17 PM
dirtpro06's Avatar
No i havent done anything yet cause i work crazy hours. Once my weekend rolls around again ill dive into it. Thanks for the info guys i really appreciate it.
bigjstang
08-25-2021 12:41 AM
4x4-runner
12-27-2016 01:58 PM
wwjr
09-07-2015 09:27 AM
JAmdor3
08-11-2015 10:53 AM
Shaun Crystal Gomban
08-02-2015 08:00 PM
Quick Reply: possible blown rod bearing
