Popping noise comming out of exhaust after head swap
Old 10-09-2009, 07:09 AM
jplasse's Avatar
Question Popping noise comming out of exhaust after head swap
I had an issue with my 22re and I bought a rebuilt motor for it, ran fine and started having problems again and turns out the shop messed up the timing chain so it bent 3 valves in the head. Took the head to a buddy of mine who works on these motors and he rebuilt the head for me. After reinstalling the head I am getting a weird "popping" noise comming out of the exhaust as if it were a sucked valve? I readjusted the valves thinking they were too tight but it is still having the same symptoms? Any help would be appreciated.
Thanks in advance
Old 10-09-2009, 08:42 AM
DupermanDave's Avatar
an after-fire? I had an after-fire because my TPS was misadjusted. But I read online it could also be caused by an improper air/fuel mixture.
Old 10-09-2009, 09:01 AM
jplasse's Avatar
What types of things could cause this improper air/fuel mixture?
Old 10-09-2009, 09:54 AM
crawlerjunkie's Avatar
And since were here, how does one adjust the air-fuel mixture?
Old 10-09-2009, 11:09 AM
You can adjust the little gear in the VAFM box (do a search for that) but I wouldn't recommend it. I believe the computer should do the corrections if the mixture is incorrect. So most people don't recommend messing with this.
if toyotas are anything like our 96 subaru, a bad O2 sensor can cause a bad mixture. Or even a bad sparkplug/spark. But this is our subaru, not a 22re.
Team420
01-12-2021 04:57 PM
voiddweller
19
05-02-2016 09:10 PM
truckmike26
10-26-2015 05:10 PM
hexrain
06-27-2015 06:17 AM
Quick Reply: Popping noise comming out of exhaust after head swap
