polyurethane bushings & SAS
I bought Energy Suspensions 8.18101 "master kit" (a while ago) for my truck. I'd like to do a SAS, and get rear springs to lift the rear. Are the only useful parts now, the cab bushings? Can I hope to sell this kit without the cab bushings? I don't think I could even use the tie-rod boots, huh?
Do SAS kits have urethane bushings in the leafs, or do you have to specify that?
Energy Suspension
8.18101
1989-95 HYPER-FLEX SYSTEM Complete Master Bushing Set Includes: Front control arm bushings, rear spring and shackle bushings, front sway bar bushings, body mounts, tie rod end boots.
8.18101
Did you mean?
8.18102
1979-85 HYPER-FLEX SYSTEM Complete Master Bushing Set Includes: Front and rear spring and shackle bushings, front sway bar bushings, torque arm bushings, body mounts, tie rod end boots.
Sure, I don't see why you couldn't sell the kit minus the cab bushings. All their bushings are available for sale individaully on SummitRacing.com. I still need to get some cab mount bushings and tie rod end boots from them here soon. DowneyOff-Road.com has some too.
Some SAS kits probably do, I know Downey's springs do.
I have the set for the 89-95 trucks: #8.18101
kawazx636
10-06-2021 03:03 PM
live4soccer7
05-11-2016 06:52 PM
punks_is_4x4
02-26-2016 04:29 PM
Toys4parts
09-26-2015 01:56 PM
