plug wires
Old 11-06-2011, 08:59 PM
turkey's Avatar
plug wires
can my plug wires be bad from overheating? i noticed all the passenger side wires were touching the egr tube could that have done anything internally without harming the outside they look fine but truck is running terribly and i can smell unburnt fuel in the exhaust. i'd like to know before i drop money on a new set cause these arent too old. how can you accurately test a plug wire?
Old 11-06-2011, 09:09 PM
toyoda88's Avatar
use an ohm meter, should be very little resistance.
Old 11-06-2011, 11:00 PM
wyoming9's Avatar
Smile
The spark plug wires should have less than 25,000 ohms resistance .
But if you see visible damage it is time for a new set
Old 11-07-2011, 12:23 AM
TNRabbit's Avatar
What brand are they?
Old 11-07-2011, 04:23 AM
turkey's Avatar
the brand is balden or belden. its a 5mm plug. ive never heard of this brand they was just put on when i got the truck so i did not replace them when i did the rebuild but i did put a set of the ngk iridum plugs in. very expensive lol.
Old 11-07-2011, 04:28 AM
waskillywabbit's Avatar
OEM plugs and wires is all you need.
:wabbit2:
Old 11-07-2011, 04:39 AM
turkey's Avatar
does the dealerships normally keep simple parts like this in stock for older trucks or will it be another wait lol
Old 11-07-2011, 04:44 AM
TNRabbit's Avatar
You can get them online cheaper; try www.sparkplugs.com
Old 11-07-2011, 04:49 AM
Really depends on the dealership. Plugs they will have in stock. Mine has wires and most things I need. If not, takes 2-3 days at the most.
:wabbit2:
Old 11-07-2011, 04:51 AM
turkey's Avatar
do they absolutely have to be OEM to run right? i had a z71 that i was told i had to run Acdelco or it woulnt run right so i spent 100 bucks on a set and they were no different from a set at auto zone i had.
Old 11-07-2011, 05:57 AM
TNRabbit's Avatar
We can't say for sure that wires are your problem, but experience here tells us OEM Denso is the better way to go.
Have you check in the dark to see if you're getting arcing at all? What do your plugs look like? How long have you had the problem? Did you do something immediately prior to the issue starting?
Old 11-07-2011, 06:32 AM
turkey's Avatar
the plugs had soot on them i changed them i was getting a code 71 egr temp sensor i pulled egr valve mod and tubes checked for clogs but it all was good i also put new crush washers on csi fuel line.After i put egr componets and csi fuel line back i can smell raw gas in the exhaust i also replaced the o2 sensor with no effect. not sure how i caused a change by pulling csi fuel line and egr componets but i did some how. almost like it went from being little lean to rich
Old 11-07-2011, 08:30 AM
TNRabbit's Avatar
Is the CSI staying open & dumping extra fuel into the intake? That or a faulty VAFM are the only other things I can think of that would suggest what you're experiencing...
Old 11-07-2011, 12:40 PM
turkey's Avatar
i pulled it out the plenum an put it in a jar turned key on an nothing happened but engine may been warm but i cant remember but even if it was warm and it was leakin wouldnt it have still leaked warm? and i dont think its the vafm cause it was an instant change. it ran decent then i pulled egr an fuel line put it all right back crunk it up and bam ran completely different.
Old 11-07-2011, 12:43 PM
turkey's Avatar
could no fire on a cylinder or more cause the gas smell in the exhaust? it also started backfiring if that helps anything. and i have a small exhaust leak after i gutted cat.
Old 11-07-2011, 04:18 PM
TNRabbit's Avatar
I think you need yo temporarily plug the csi hole &is run it to see if it's leaking....anyone?
Old 11-07-2011, 04:37 PM
turkey's Avatar
plug the fuel line of pull injector out of plenum and block off hole? where would i get something to block it off with?
Old 11-09-2011, 06:55 AM
turkey's Avatar
i check plug wires they all had pretty much no resistance but one would go from 1000 to 3000 ohms? that one bad?
sandyota
02-04-2021 11:16 AM
montanatruck
02-26-2017 07:07 AM
raptor510
02-17-2017 07:11 AM
256mbaker
07-31-2015 06:45 PM
88runnergomas
07-09-2015 01:12 PM
Quick Reply: plug wires
