| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Plug for the alternator
__________________
87 longbed, 3rz, tacoma dash, bobbed, SAS'ed, gears and more. My build----HERE More web wheeling- Just getting started so come join us Asphaltsux |
#2 (permalink) |
MR2 alt upgrade
http://www.off-road.com/toyota/tech/100alt/index.html Northwest Regulator (18002426367) makes plugs and harness' for alternators. I picked a converter for when I swap the 4runner alternator to the mr2 alternator. #50-160159 Converts Toyota round plug internal fan alternator to replace oval plug Toyota. http://www.nwreg.com/
__________________
1995 4Runner Pewter Pearl V6 Auto Front Husky Liners, Bushwacker Flares, Manik Tube Steps, White Face Indiglo Gauges, TJM T17 Bumper, K&N FIPK, Scion 6 Disc MP3, Clear Tails, 2.25dia exhaust W/Carsound cat & Magnaflow Muffler, Bridestone Dueler A/T Revo, American Racing Mojave Teflon, Hood Scoop "There is no limit to stupidity, so I think there's still a lot more I can do." Shinichi Watanabe on directing Excel Saga |
#3 (permalink) |
I have an alternator I would be willing to sell ...
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks! Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R 96 Impala SS: My own personal cop car Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place Stop with the mods and get on the trail! Pix at www.4wheelingoh.shutterfly.com/action |
#4 (permalink) |
Check your motor mounts, it sounds like your engine is moving a lot and the alt wiring doesn't have the slack to allow that much movement.
__________________
~Dale~ 93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000. |
#5 (permalink) |
motor mounts are new. I just replaced them when we replaced the motor. i think i figured it out. My truck went through a week thing of killing alternators. I just replaced it But noticed the plug was pretty stiff. A few weeks ago i was going through and tightening some bolts and pulled off the wiring...i was half asleep when i put it back on and think i broke the tab on the alternator. I called a buddy at Checker and he said he would cover it and just bring it in. So i took it up he wrote down that the clip was broken and i got a new one. LOL I gotta put the new one in but i will get to that this week before we go up this weekend.
Its been driving me up the wall tryin to figure it out. I hope this fixes it.Im finding that after trucks sit for a long time they just rot away. My fix/mod it list for the week alternator and ground wire now, put the webber carb on, replace the coil,gasket on the manual pump..swapping the pump too,new plug wires(again!) maybe throw the header on but i still dont know if i wanna run it on my truck. add diff breathers,rear wheel cylinder and shoes. i havent even got to the fun stuff yet.....Im selling my runner caue one rig is more then enough work to keep me busy!
__________________
#6 (permalink) |
Is the plug flush with the rear of the alt cover or does it extend or protrude beyond the cover (this is with the connector unplugged) If it extends, there is an adaptor the rebuilders put onto the original regulator. Just unplug the adapter and plug your harness right into the regulator without the adapter.
__________________
Toyota Master Diagnostic Technician "MDT" 1998 Toyota Tacoma TRD V6 4WD 5 SPD 1998 Chevrolet K1500 1999 Toyota Camry 2003 Toyota Highlander 4WD 2007 KTM 85SX 17/14 2006 KTM 300XC-W 2005 KTM 65SX 2004 Kawasaki KLX 110 2003 Honda XR50 2002 Yamaha TTR 125L 2002 Kawasaki KLR650 2002 Suzuki Eiger 400 4WD 2004 Cargomate<--link GeePaw® Racing<--link |
#7 (permalink) |
what is the pourpose of this adapter?
__________________
3vze, 4x4, sr5, 90, auto, LSD 2x dB Drag World Finalist 2003 Nopi Nat. Street B champ 2004 SBN Street C champ 2004 SBN Advncd NW Champ 2004 Former WR Holder in NW. SPL: 159.8db @ 42hz In loving memory of Jamie Riggs 5/15/85 - 10/8/04 |
#8 (permalink) |
The rounded part of the regulator gets broke, (usually just a chip that never affects performance) either from the installer, rebuilder etc. So a guy buying a reman unit sees the chip and sais no way, besides, it shows they "reclaimed" the regulator (in othjer words, its used) and this piece just hides the break. I have seen this cause trouble on several occasions. Just remove it, plug the connector directly into the alt without the adapter. I was a rebuilder for 4 years prior to my current job now, that was some time ago, but havent forgetten a thing. I'm a whiz on electrical (licensed HAM radio operator too) and know my way around every alt out there, ie automkotive, every industrial one made, etc. Same goes for startyers, but charging was my specialty!
__________________
#9 (permalink) |
There is an o-ring that goes around the plug. I have had it where it comes off and gets pushed down in the plug hole. Then when you plug it in it does not sit all the way because of the o-ring.
#10 (permalink) |
i will check for the O ring when i instal it today
Thanks for the heads up
__________________
| Tags |
| 18002426367, 50160159 |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| wanted - alternator plug/connector | apalmer1 | The Classifieds GraveYard | 3 | 03-21-2007 03:47 PM |
| How do I get the alternator out? | linuxrunner | 86-95 Trucks & 4Runners | 29 | 01-13-2007 10:16 AM |
| Ciger. lighter plug/ DC plug? | Guardian_Saint | 86-95 Trucks & 4Runners | 1 | 12-14-2006 12:53 PM |
| Coil on plug spark plug boots. Does anyone make just the boots?! | JamesD | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 07-19-2006 10:10 AM |
| wrong alternator by Mr Alternator | funrunner91 | 86-95 Trucks & 4Runners | 21 | 07-03-2006 11:06 AM |
