pls help egr delete in progress
Old 10-20-2010, 09:06 PM
IngSoc's Avatar
So a few hose questions. I got a 92 22re, hose that goes to the fuel pressure reg Hoes where? Next is PCV valve and break booster what one is on top? I trunk that's it for now
Old 10-20-2010, 10:01 PM
IngSoc's Avatar
Any one pls?
Old 10-21-2010, 12:13 AM
myyota's Avatar
The hose for the fuel presure regulator goes to the vsv on the valve cover and then from the vsv to the black vacuum port at the back of the upper intake. If you want to bypass the vsv you can run the vacuum hose from the fuel presure regulator to the black vacuum port on the upper intake. PCV hose goes on the bottom, brake booster hose on top.
Old 10-21-2010, 09:18 AM
IngSoc's Avatar
So there is 2 hoses coming for the intake? 1 to the charcoal and I to the fuel? Any specific ports? I got 4 small ones
kawazx636
10-06-2021 03:03 PM
A2theK
10-14-2015 07:10 AM
nerofiend
09-22-2015 07:17 AM
accuracy
09-20-2015 07:44 PM
Boomer8404
09-10-2015 09:01 AM
Quick Reply: pls help egr delete in progress
