Please help won't start
Changed knock sensor wire 91 3vze now it won't start everythings plugged in have spark, plugs are getting wet fuel pumps pumpin rolls ten times fires quits thats all i can get out of it any help appreciated
abecedarian asked me to ask you if the intake pipes are all hooked up and the distributor is set properly and is not out 180 degrees or something.
Really wet plugs can keep your rig from starting. There is a fuel return line that is mixed in with all those vacuum lines on the passenger side. Make sure that your lines are hooked up properly.
