Please Help Will Not Idle When Between Hot And Cold
AFTER THE TRUCK (92 3VZE) HAS GOTTEN TO RUN TEMP AND THEN IS TURNED OFF FOR A WHILE (LIKE GOING INTO A STORE FOR A FEW MINUTES) IT DOESN'T WANT TO START AND WILL NOT IDLE WHEN IT DOES START. AFTER IT GETS BACK TO RUN TEMP OR WHEN COLD, EVERYTHING IS FINE.
If it hasn't been done in a while, the fuel filter may be getting plugged.
Then maybe check the coolant temp sensor for the ECU.
It sounds like the 'heat soak' that occurs when you shut a warm engine off may be pushing the temp sensor out of range.
the1998sr5
27
11-17-2015 09:30 AM
Dennisx2
08-04-2015 01:26 PM
