Please Help Identify this bracket
Old 12-05-2009, 10:43 AM
Nuke's Avatar
So I'm an idiot. I've got my 22RE almost all back together after a HG and TC replacement but I don't know where this bracket is supposed to go. All the accessoriess look right without it. Please help--I need this truck back together to go pick up a Christmas tree. Thanks.
Old 12-05-2009, 10:53 AM
camo31_10.50's Avatar
it goes around the water pump inlet...pretttyyy sure it's for the lower alternator mount aint it guys?
Old 12-05-2009, 11:00 AM
Nuke's Avatar
Found it. Part of the power steering bracket--it stradels the outlet of the water pump from below.
Old 12-05-2009, 11:02 AM
LD
LD's Avatar
that is a bracket for power steering pump. the center hole at the 'y' mounts to the back of the timing cover just below the bypass pipe. the main power steering bracket will bolt between the two legs. just about that position in the photo, when viewed from drivers side fender.
scott90
10-04-2015 09:21 AM
voiddweller
10-02-2015 07:47 AM
ktm192k
10-01-2015 08:47 AM
Brodetski
09-30-2015 11:50 PM
tysen86
09-25-2015 11:15 PM
Quick Reply: Please Help Identify this bracket
