Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
Please Help: Charging Problems
If anyone could help me I would appreciate it.
The charging system in my '90 4-R is all jacked up. I believe it began a while ago at the car wash. I was planning on doing some engine work so I was going to clean the engine compartment. I misted the motor with Castrol Super Clean and used the pressure washer to hose everything down. I was carefull not to direct the high pressure spray directly at the distributor and the alternator, but maybe I wasn't careful enough? Anyway, a day or so after the car wash I get the flickering brake and battery lights, but everything seems to be normal. I went ahead and ordered new brushes anyway knowing that they're probably due for replacement. While waiting for the brushes the battery went completely dead overnight. Nothing was left on so I really can't explain this one. Luckily the battery was still under warranty so I went it and had it replaced after it tested bad. With the new battery the charging system went crazy. The volt meter in the dash was dang near pegged at 18v and the battery and brake lights in the dash were constantly on. I turned on both front and rear heaters, the radio and the headlights in order to get a voltage drop to try and keep from damaging the system. This brought the voltage down and would keep the battery and brake lights off most of the time. It seems during this time that the system was overcharging? This went on for about 3 days. After this the alternator wouldn't do crap, the voltage dropped near the bottom of the 'normal' level and it was obvious that the 4-R was running strictly on batter juice. I finally pulled the alternator to replace the brushes and the old ones looked house, about 85-90% the size of the new ones. I went ahead and replaced them anyway and cleaned up all the contact areas. This didn't do anything for me and the system still isn't charging. Anyone have any ideas on what could be going on?
__________________
1990 4-Runner V6 5spd Last edited by Faded : 12-07-2005 at 07:15 AM. |
| Sponsored Links |
#2 (permalink) |
Battery terminals nice and tight? If there is slop, the alternator will read funny and sometimes do what you're talking about.
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks! Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R 96 Impala SS: My own personal cop car Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place Stop with the mods and get on the trail! Pix at www.4wheelingoh.shutterfly.com/action |
#3 (permalink) | |
Quote:
__________________
1990 4-Runner V6 5spd |
#4 (permalink) |
if you havent already take the alt to get tested, could be a bad regulator or diode
__________________
Dan 84 4runner sr5 Ford 302 T-18 4spd yota t-case yota front and rear both open 37X13.00 boggers 88 4runner 22re 5spd |
#5 (permalink) |
I thought toyota used externally regulated alternators? (i can never remember)
__________________
94 EX cab, 5speed, V6, locked, ARB bar, NWOR headers 92 4runner, auto, V6, OME suspension, Downey headers |
#6 (permalink) | |
Quote:
__________________
Dan 84 4runner sr5 Ford 302 T-18 4spd yota t-case yota front and rear both open 37X13.00 boggers 88 4runner 22re 5spd Last edited by DudeBud : 12-07-2005 at 03:19 PM. |
#7 (permalink) |
Called my buddy at the salvage yard and he hooked me up with a used one - $35. Went home and slapped it in and it works fine. As far as I can tell it looks as if both are internally regulated. Still don't know what's wrong with the old one.
Thank you for the replys, didn't want a new alternator for $150+ that the parts stores were asking, but for $35 I couldn't go wrong. ![]()
__________________
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| charging problems!!! | fatmatt473 | Pre 84 Trucks | 4 | 06-17-2007 08:46 AM |
| Charging problems...tired of being pushed off | s_wall98 | General Electrical & Lighting Related Topics | 27 | 12-07-2006 11:12 PM |
| 84 4Runner Charging Problems | RallyRoach | 84-85 Trucks & 4Runners | 13 | 11-23-2006 03:45 PM |
| charging problems getting annoying | weakyota91 | 86-95 Trucks & 4Runners | 2 | 11-22-2006 09:34 PM |
