PLEase help 1990 truck 22re power loss please help
hi i have a 1990 22re built with a soild axel swap and leaf spring swap with 40 in tires
i drove it home the other day and started lossing power and vac leak
replaced all vac line, fuel filter,intake,maf sensor,distubitor,cap rotor,and coil
truck at start up runs fine and idles pefect at 900 rev it it bogs down a bit then pics up then you drive it down the road and thiers no power at all it takes 5 min just to get to 3k rpm just cant figure it out
btw if you unplug the tps sesor the truck runs the exact same not a change with or with out it thoughts thanks for your help
zd92655
03-06-2022 12:58 PM
DacodaYota
09-02-2015 02:13 PM
