Pittman/ Idler arm needs replacement
Whatever it's called. the arm opposite the steering box arm connected to the relay rod. Is this one piece (arm and bracket)? Where can I get a new one besides a dealer and what kind of a job is it to do myself. TIA!
Thanks for the replies on this. I'm not sure if the wear is in the shaft area or the ball connection to the relay rod yet. Had an alignment done and the shop advised me of the problem. Guess I'll raise the truck and shake things around to see where the wear is. I didn't realizise the the idler arm was rebuildable. It looked like one piece to me. My question was, can you buy the arm seperately from the bracket them just replace the bushings in the bracket. I haven't taken anything apart yet so I'm not sure what I'll need to buy in advance of performing the job. Hope this all makes sense.
NO! DAMMIT!!! SEARCH!!!
The part #s for the bushings are posted umpteen times on this site. You can also buy them, or the idler arm assembly, at ANY autoparts store! And NO, you can either buy the bushings and replace them, or replace the entire idler arm assembly. INFORMATION ALSO POSTED ALL OVER THIS SITE AND THE INTERNET IN GENERAL!!!
Can we please close this thread now? It serves no purpose AT ALL!!!!!!!! This is just about as stupid as asking how to change a flat tire. Not to mention, FRICKEN UBER-NEWBIE TECH!!!!!
Sorry hippy. While it is true you can get them anywhere, I prefer the ones 4crawler has. Yes, searching is great and usually turns up what they need, but there are times when a search returns nothing useful.
It was posted, I replied. You are still the man mud!
rockauto.co for the whole replacement arm and toyota part numbers 90385-18068 for early trucks and 4runners 90386-19005 for 93 to 98 trucks and the dust seal part number is 90304-31012 here are the links to where i found this https://www.yotatech.com/forums/f2/t...s-right-70825/
searched for idler arm bushings beleive it was the 3rd post down
https://www.yotatech.com/forums/f128...ld-how-144151/
how to rebuild in the tech write up section under maintenance and repair only one page to search through there
Thanks all! I'll follow your posted links and go from there. The alignment only cost $50 and was worth it since I had them put on a new set of tires, I didn't want to tear them up before I got around to fixing the idler arm issue and it made a world of differance. Both tires and alignment were needed desperatly.
just remember if you do not get the Autozone FA5040, McQuay-Norris FA5040, or Kragen/O'Reilly FA5040 brand you will not be able to use the sdori bushings.
Any other brand/manufacture oem or not is an inferior setup to the above mentioned.
A bad idler arm will still tear up tires. I don't care what you say.
Hello. i am new to this forum. im not sure if i should be posting here but this is my problem: i have an 86 4runner, just bought it. the camber is off in both the front tires (negative camber). i took it for an alignment thinking that was what i needed, the dbag gave me some run around about how he couldnt do it but also suggested that i replace the idler's. since i knew the bearing was loose in the front right, i replaced it; this fixed some of the camber problem but it is still off. so i guess my question is, will replacing teh idler arms fix me up?
Sounds like you're new to a lot of things...the steering linkage has NOTHING to do with camber. Do you have ball joint spacers installed?
