pitman and idler arm
Old 09-25-2014, 05:02 PM
Dustin Egle's Avatar
1991 4x4 toyota pickup IFS
Is there 2 of each in the front end or 1 of each? I need to replace them, so I was wondering what to buy!
Old 09-25-2014, 05:04 PM
JasonYota's Avatar
There is one idler and one pitman arm.
No to be rude but have you looked at the underneath of your truck??
Old 09-25-2014, 05:26 PM
scope103's Avatar
Originally Posted by JasonYota
... have you looked at the underneath of your truck??
Print this picture and take it with you.
http://personal.utulsa.edu/~nathan-b...g/16steer0.pdf
Old 09-25-2014, 06:33 PM
Yeah quite a bit honestly...I just don't know anything about IFS whatsoever. Used to solid axles! But thank you very much for the answer!
Old 09-26-2014, 09:09 PM
highonpottery's Avatar
If buying idler, get the part number FA5040 idler arm branded by mcquay Norris, autozone, oreilly. It's stronger/thicker design than toyota version an all other stock replacements. Even Better is the fa5040+SDORI Brass bushings inside+idler brace. Ultimate idler is the total chaos idler. Good luck!
ladybugRC
458
08-21-2020 10:41 AM
ktm192k
10-01-2015 08:47 AM
JookUpVandetti
09-30-2015 08:58 AM
tylermx71
09-29-2015 08:49 PM
crash813
09-27-2015 07:15 AM
Quick Reply: pitman and idler arm
