Pitman Arm Woes
Old 04-15-2009, 02:48 PM
T4L
T4L's Avatar
Pitman Arm Woes
I've searched and I've dropped a line on another thread to no avail. I'm having some Pitman arm issues.
Old 04-15-2009, 02:56 PM
T4L
T4L's Avatar
Pitman Arm Woes
I was told I couldn't get my 4Runner aligned because it needed a new Idler Arm and a new Pitman Arm. The shop quoted me something over $400 for the parts/labor, I said no-thanks. I picked up an Idler arm and swapped out the old one...piece of cake. The Pitman Arm had to be ordered and was expected next day. I picked it up along with a puller and got to work. Broke that puller and messed up that whole day(yesterday). Today, went back to the parts store, exchanged the pitman arm puller, went back home and got to work. Finally got the old pitman arm off, put the new one on and tightened every thing down and found a problem.
The castle nut threads too far up on the stud so that the cotter pin is useless. If I try and remove the part, I'll damage it and be stuck with the cost. Could I use a nut, torqued to spec, to push the castle nut out far enough that it engages with the cotter pin?
I've been trying to get this 4Runner roadworthy all week. I need it for a camping trip this weekend.
I'm broke and frustrated and don't know if I've fixed my vehicle or just made it worse.
If I'm just an idiot...flame away, just do it constructively
Old 04-15-2009, 03:15 PM
one2high's Avatar
Why not redrill the hole with a carbide drill and install the cotter pin? You could then carefully cut the excess off and touch it up with a small grinder.
Old 04-15-2009, 03:16 PM
totally a bro
Staff
vital22re's Avatar
do you still have the original castle nut? If yes check the hieght maybe it'll work. if it will, try having a shop use air tools to bust it loose. Or pick up some air tools and bust off the nut that way. If that doesnt work, you may be able to get away with a stack of washers.... but i think that the pitman arm you picked up may be no good. (taiwan parts suck)
Old 04-15-2009, 03:18 PM
Matt16's Avatar
I shimmed my idler arm with one washer to get it to sit in a position that the cotter pin engaged the castle nut.
I suppose you could get a second nut and thread in on first, torque it, then tighten the castle nut up against it and pin it. you could also drill a new hole. Its easy with a tiny pilot hole, then go to a larger bit.
Old 04-15-2009, 03:24 PM
T4L
T4L's Avatar
Here is what I did. The old/new castle nuts were different sizes, but the same thread, so I used them both. I torqued the 1st one to spec then added the 2nd w/ cotter pin.
I hope I don't get laughed out of the alignment shop.
Old 04-15-2009, 03:28 PM
Matt16's Avatar
Structurally, there isn't anything wrong with that. if you're broke, why don't you align the truck yourself? Search "driveway alignment", I did a writeup.
Old 04-15-2009, 03:29 PM
Ardent's Avatar
Well, now you have the added benefit of a double-nut! Better than it being too short and not being able to put the pin in at all!
Old 04-15-2009, 03:38 PM
T4L
T4L's Avatar
I considered that.......these are all 1st time repairs and are a little intimidating at first. I havn't ruled it out.....need to look it over some more. I'm learning as I go. Also, I'm the one at home with the kids while the wife works so time is always against me.
Old 04-17-2009, 09:33 AM
T4L
T4L's Avatar
Alignment complete (performed at a garage), steering wheel is straight, I am happy(ier) now. My double castle nut solution raised no eyebrows or questions. I'm going camping and trout fishing. Have a good weekend folks.
ladybugRC
458
08-21-2020 10:41 AM
ktm192k
10-01-2015 08:47 AM
JookUpVandetti
09-30-2015 08:58 AM
tylermx71
09-29-2015 08:49 PM
crash813
09-27-2015 07:15 AM
Quick Reply: Pitman Arm Woes
