Piston Stop damaged piston 22re
Old 05-13-2014, 11:10 AM
ChipsnGuac's Avatar
I forgot to remove the piston stop and I rotated the crank by hand all the way through TDC. The piston stop was only slightly touching the piston and I didn't notice any additional resistance rotating through TDC.
The piston now has a slight indent (about the size of this text).
Does the piston need to be replaced?
Old 05-13-2014, 11:18 AM
HighLux's Avatar
Nope. Long as there are no cracks etc. A pic would let me say 100%.
JasonYota's Avatar
Interested in this as well.
Old 05-13-2014, 11:22 AM
ChipsnGuac's Avatar
Thanks for the quick reply. I'll try and add a picture tonight.
I was looking for cracks and didn't see any but that's looking through the spark plug hole.
Would doing a compression test, by hand rotating the crank, indicate anything?
Old 05-13-2014, 11:50 AM
HighLux's Avatar
at least tell you if there is a hole in it...lol
Old 05-13-2014, 11:52 AM
HighLux's Avatar
ooohhhhh ohhhhhh!!! Harbor Freight has a inspection camera that is cheap....one could use it and take it back if you didnt want to keep it. (Id keep, cause they are cool, but dont make any jokes to the woman about using it...you will get slapped.)
Old 05-13-2014, 12:04 PM
JasonYota's Avatar
Lol is that coming from personal experience?
Old 05-13-2014, 01:33 PM
HighLux's Avatar
No..I see them there when I go in...but have never had a reason to buy it.
I "listen" to my motor...it tells me whats wrong. Like a Toyota whisperer.
Old 05-13-2014, 01:45 PM
scope103's Avatar
No. You'll never be able to crank it fast enough to tell the difference between ordinary blow-by and a crack of any size.
Or you could just save $75:
Amazon Amazon
(you ought to mike a spark plug first; I'm not sure a 14mm camera head (16mm HF) will fit easily. But you can get camera heads down to about 7mm for a little more money.)
Old 05-13-2014, 01:53 PM
HighLux's Avatar
Or you could just save $75: http://www.amazon.com/Waterproof-End...ords=borescope
Wow what an awesome find on the little scope. Bravo. Now he could turn it over by hand to at least tell if it is building any compression at all...it sure as hell wouldnt build any if he managed to poke a hole in a piston.
I seriously doubt there is a hole of any sort. I just thought the scope would at least set your mind at ease.
montanatruck
02-26-2017 07:07 AM
09-04-2015 09:27 AM
Backcountry411
07-24-2015 08:06 AM
ShakinIt2x
07-21-2015 06:20 PM
PlayAwhile
07-20-2015 11:36 AM
Quick Reply: Piston Stop damaged piston 22re
