Piston Slap? - YotaTech Forums
Go Back   >
Piston Slap?
LinkBack Thread Tools Search this Thread
Old 07-06-2006, 08:49 PM   #1
Sonofmayhem's Avatar
Piston Slap?
Ok, This week we got a lot of rain and i headed down to an OHV area, and went threw a HUGE puddle, made it threw, but at the end it died. We got it running after a long and hard roll start, then came the horror. :pat: A loud slaping. I did clear out the cylinders of the water. I didnt have any power and i could feel really hard tapping on my clutch pedal and gas pedal, is this piston slap? Im looking at a rebuilt engine for cheap that i can build on. Or is it a bearing or something else? thanks
Sonofmayhem is offline   Reply With Quote
Old 07-06-2006, 09:07 PM   #2
If anything you probably bent a rod or the crankshaft. Does the engine vibrate alot more?
Chuki is offline   Reply With Quote
Old 07-06-2006, 09:22 PM   #3
Im not sure, i don't think so, but could it be fixed w/o taking apart the head and what not? Do you know an average to get this fixed professionally? thanks.
Old 07-06-2006, 09:40 PM   #4
Sounds like some major internal damage was done to the motor, probably a bent rod. If you feel the vibration through the clutch it's got to be vibrating more.
Piston slap is a distinct noise hear when the pistons move around laterally in the cylinder due to the cylinder bore having expanded(usually wear related) or due to the fact that the pistons have not expanded, as is the case on many race built motors with forged pistons.
WillsFJC is offline   Reply With Quote
Old 07-07-2006, 02:18 AM   #5
Ganoid's Avatar
If it is a bent rod (sure sounds like it) and you tear it apart now as opposed to continuing to drive it you may get by with just a rod and some bearings compared to a crank or block due to abnormal wear.
Ganoid is offline   Reply With Quote
Old 07-07-2006, 02:50 AM   #6
KTMR1der03's Avatar
Same exact thing happened to me. Once I cleared all the water from the cylinders it threw a rod and cracked my block. Run it again and see if any kind of fluids pour out anywhere, then you will know if the block is good or not.
KTMR1der03 is offline   Reply With Quote
Old 07-07-2006, 04:43 AM   #7
TNRabbit's Avatar
Did you clear the water from the cylinder before or after you restarted? How much came out of the spark plug holes? Ingesting water can do one of several things; the worst of which would be bending a rod; the next worst would be blowing a head gasket. It needs to be looked at by a professional before you start it again or you could do more internal damage.
TNRabbit is offline   Reply With Quote
Old 07-07-2006, 07:19 AM   #8
I couldnt start it, the starter died after the puddle, so i let everything dry, took out the plugs, and cranked it, im not sure how much water but the 3rd cylinder was damn near full. So if i were to buy a rebuild kit from engine builder, what kind of machine work would be needed, if the block is good, after a bent rod? should i try to find a cheapo 22r rebuild it, and switch all of my 22re stuff over?
thanks
Old 07-07-2006, 07:45 AM   #9
snap-on's Avatar
depending on your time frame you can pull yours out and tare it down see what work it needs. or by a bone yard 22re and rebuild it then just swap motors. Then you can tare down your old motor and see what it needs and if its worth rebuilding or just sell the parts.
snap-on is offline   Reply With Quote
Old 07-07-2006, 09:17 AM   #10
thats what i plan on doing, this guy is gonna sell me a complete 22re w/ a bad valve, and needs some pumps. So can i use my valves? or do i need to get new ones? while i have the new engine out im gonna replace the timing chain, head gasket and everything else that doesnt need machine work.
Old 07-07-2006, 09:22 AM   #11
You can't just swap valves from motor to motor, at the absolute minimum you'll need to lap the valves in, but most likely you'll need to take the head to a competent machine shop in your area and have it re-done, honestly there's no reason not to since you're already in there.
Old 07-07-2006, 02:12 PM   #12
yeah, it sucks the head was just done. and everything else, thats fine ill have like 500 to buy all the parts to put them in the redone engine.
I just towed the truck home, the pinging isnt as bad but still bad, so im gonna tear into it when i get the new engine, i start a new job tommorrow so i should be making enough so im good to go, any other suggestions?
thanks
Advice on a possibly bad 2TR-FE and shady dealer. charlie_fong General Vehicle Related Topics (Non Year Related) 0 09-27-2015 11:06 PM
Timing replacement trouble PBRaddict#1 Newbie Tech Section 3 09-22-2015 08:50 AM
Rear disc brake conver. No E-Brake! HELP! theBAYsic General Vehicle Related Topics (Non Year Related) 8 09-16-2015 06:21 AM
R12A Refrigerant highonpottery 86-95 Trucks & 4Runners 14 09-14-2015 01:46 AM
2.7 clattering noise Streetrod19772000 95.5-2004 Tacomas & 96-2002 4Runners 0 09-10-2015 07:22 PM
Tags
1990, 22re, 43, 4runner, engine, gasket, head, piston, rebuild, replacement, rod, slap, slaping, slapping, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
